Would you recommend Raybestos brake pads?
Old Nov 13, 2013 | 03:38 PM
Blue_XJ8's Avatar
Default Would you recommend Raybestos brake pads?
So I replaced front rotors and pads some ~5k miles ago. Braking was still not great and knew I had to handle the back soon enough. I strated to get annoying squeeeeeek noise (mostly a traffic light stop) and figured it might be the back ones. I replaced the rear rotors and pads this past week-end. Nice braking improvement, no change in Squeeeek $%^$^%. So perhaps it is the front. I did not buy high end stuff, and can't even recall what brand I used on the front (all I know not the same than back). I have read a lot of threads here and there are so many possible reasons and remedies. But I felt like upgrading my front pads anyway in the hope it might also cure the squeeeeeek. Any thoughts on Raybestos semi-metallic? Rockauto sells at ~$65 but seems like I can find on Ebay for ~$45
Old Nov 14, 2013 | 01:34 PM
Blue_XJ8's Avatar
OK, went for a set of Wagner semi-metallic Thermoquiet (from Advanced Auto). Got them 30% off so ~$45 instead of ~$65. I put some of these on the rear so will stay consistent, and hope the squeeek will go and improve braking overall. Will let you know
Old Nov 14, 2013 | 01:58 PM
Doug's Avatar
Raybestos offers several different grades/types of semi-metallic pads. I'm sure they're not "all created equal"
On my older Jags I had great results from Raybestos "RPG Professional Grade"....or something like that. I'll try to get the exact name
However, nowadays I think Akebono pads are the greatest and would prefer them over any other
Old Nov 14, 2013 | 02:00 PM
Blue_XJ8's Avatar
Thanks Doug. Good to know.
Old Nov 14, 2013 | 04:03 PM
XJRChad's Avatar
I work at an auto parts store, so I am quite familiar with Raybestos. The Professional Grade pads are very good quality. We also carry a brand called Evolution (by Power Stop), which are ceramic and $33 cheaper than our semi-metallic PG Raybestos. My XJR has these pads all the way around, and I am very happy with them.
The advantages of ceramic pads are that they are a lot quieter than semi-metallic pads, and also produce much less brake dust. The disadvantage of ceramic pads is that they are tougher on brake rotors. Don't go with cheap rotors if you put ceramic pads on.
Old Nov 14, 2013 | 10:46 PM
thesameguy's Avatar
Are these the Z16 pads? I have on numerous occasions nearly bought one of the Powerstop kits with rotors and pads, but always chicken out. Good to hear they are decent!
Old Nov 15, 2013 | 05:51 AM
xjay8's Avatar
Brian....cheap is as cheap does ;o)
The brakes on these cars are simple and efficient.
The concensus seems to be for Akebono Ceramic pads as the pad of choice.
I fitted these 60,000klm ago and are really great, NO SQUEAL, NO DUST and great braking.
The only thing is they do take a bit longer to bed in.
When replacing pads, always make sure mounting areas are clean and free of debri.
Smear a litle 'anti-squeal' on back of pads and a dab of ant-sieze on caliper mounting pins and you're good to go ;o)
The discs on these cars are good for one light scimming before they need replacement.
I'm on my second set of rotors in 200,000klm
Old Nov 15, 2013 | 07:53 AM
XJRChad's Avatar
We don't carry the Z16 pads, so I don't know about those. These are Evolution pads. I can say that, with 15,000-20,000 miles on the ones on my XJR, they are surprisingly good. No squeaking and no dust. Car stops on a dime, also.
Old Nov 20, 2013 | 04:00 PM
Blue_XJ8's Avatar
Glad to report that new Wagner "ThermoQuiet" pads and a good greasing of the guide bolts did the trick. Good braking and no more squeeking!
H20boy
Dec 24, 2024 03:23 PM
Jefro
Sep 15, 2015 01:44 PM
SeanU
Sep 13, 2015 02:45 PM
1964Daimler
Sep 9, 2015 11:28 AM
JagLove86
Sep 6, 2015 10:36 PM
