X308 thinks it's in Reverse during Drive
Old May 6, 2020 | 05:13 AM
X3082002's Avatar
Default X308 thinks it's in Reverse during Drive
Hello! I have a problem with my 2002 x308 XJ Sovereign. The reverse lights are on and parking sensors work when in Drive mode. It seems that it thinks that it is in Reverse mode all the time... What is the most likely cause? J-gate (is there a sensor?) or it the control module not okay? Any help and explanation are very welcome!
Old May 7, 2020 | 02:54 AM
JagV8's Avatar
Check both ends of the shift cable, starting with the trans end, in case it's loose or stretched.
Old May 7, 2020 | 04:28 AM
X3082002's Avatar
Thx. Shifting itself is absolutely, car drives perfect. Switching from P to R to N and D is fine. But in all positions, the parking sensors work and reverse lights are on. So how can it be related to this cable?
Old May 7, 2020 | 02:45 PM
JagV8's Avatar
Now you've added that data I don't know and would not have posted
ben30
XF (X260)
Apr 7, 2018 07:37 PM
dneider
Jan 12, 2018 09:19 AM
DRIVER12
Aug 17, 2010 04:55 PM
