X350 radiator core with x308 plastic tank possible?
Old Mar 14, 2023 | 08:47 PM
RA110623's Avatar
Banned
Default X350 radiator core with x308 plastic tank possible?
Hi guys Time to replace the radiator the leaks is in everywhere
I'm thinking to buy new 2004 xj8 radiator then remove the tank and install x308 plastic tank is that possible? Ist same core size ?
Otherwise I have to buy the junkyard radiator which is not in that good shape
Old Mar 15, 2023 | 04:09 AM
Hooli's Avatar
Can't you get your existing rad recored? That's what I'd look to do if I couldn't get a new one.
Old Mar 15, 2023 | 09:55 AM
RandyS's Avatar
Yes indeed, your best bet is a radiator shop. They can do the job right and you seldom
need to worry with it again.
Old Mar 15, 2023 | 12:51 PM
RA110623's Avatar
Banned
Yup definitely I will take both radiator to the shop but I need to make sure if the size are the same can't do the job by my own though it's not that much difficult I saw they just remove the tank then sealant then pressure test and done
Old Mar 16, 2023 | 05:26 AM
Hooli's Avatar
If you're going to a rad shop anyway, just ask them to recore the rad you've got. Shouldn't be any need to buy the wrong rad to take bits from.
Old Mar 16, 2023 | 10:32 AM
RandyS's Avatar
i totally agree...the recore would be the best option.
Thorsen
Oct 27, 2022 06:35 PM
Roger95
XJ40 ( XJ81 )
Oct 9, 2022 11:57 AM
BlackKat
33
Jun 21, 2019 05:06 PM
bpwu
Feb 21, 2018 07:55 AM
jam1white
Aug 8, 2012 09:17 AM
