XJ6 (X300) Drivers Air Bag On XJ8/XJR (X308)?
Old Sep 14, 2015 | 08:39 PM
xjrjag's Avatar
Default XJ6 (X300) Drivers Air Bag On XJ8/XJR (X308)?
Does any know if the drivers side air bag on the steering wheel can be swapped from X300 XJ6 to X308 XJR? I don't NEED a new air bag...I just want the fancy growler instead of the embossed XJR on the cover.
Old Sep 15, 2015 | 05:51 AM
Daim's Avatar
Nope. Wont really work. My X308 has a growler airbag.
Old May 4, 2017 | 04:41 AM
Sean B's Avatar
It would need comparing, if they mount on the wheel in the same place, and the pigtail connector is the same then I don't see why not. If they don't - then it's a case of drilling out the rivets on the facia of both, then re-riveting onto the 308 base.
Old May 4, 2017 | 12:12 PM
Daim's Avatar
Wow, that is some digging Sean Yonks old thread
And won't work, as the X308 airbag unit has cutouts for the buttons I troed to fit a better condition X300 one to my X308. Plugs are the same but the buttons require some cutting of the airbag.
Old May 4, 2017 | 03:03 PM
Sean B's Avatar
I guess just buying a vanilla s/h XJ8 airbag and fitting it would do it then?
@Daim, I don't understand you? When I rebuilt my car I needed the 'R' emblem airbag as it's unique to the 100 so I had to drill out and rivet it onto another airbag frame.
Old Jul 3, 2017 | 09:12 PM
niche's Avatar
EDIT: Disregard
Old May 9, 2018 | 09:36 AM
Daim's Avatar
Wrong thread...
Old May 9, 2018 | 04:43 PM
Lady Penelope's Avatar
I have a replacement X300 airbag on a X300 . The growler badge was ripper out by the PO as a souvenir . So I found a X300 airbag assembly to replace it . The growler pin has 3 thin tabs on the outer perimeter that punch through the leather and bend over . No radio button cutouts . The X308 from what it sounds may be a rivet .
Just the growler may not be avail unless you buy a whole airbag assembly or may find a donor already blown . To get to the bent over tabs you would have to drill out the pop rivets that hold the bag in a container frame to get to that inside surface . Then you would have to pop rivet it back to the closed container form .
You can have my oroginal X300 airbag assembly and see if it fits as the airbag was blown and cut away
There is a salvage company in LA that seems to go through alot of X300's that may have a blown bag to salvage from . I would recommend yourself to remove the growler .
Old Jun 6, 2018 | 10:15 PM
greg21's Avatar
Default Ball joints
Got all 4 ball joints done this was actually easy and nothing note worthy. Easiest ball joints ever. Although this does not make up for everything else.
Old Sep 20, 2018 | 07:09 PM
darknia's Avatar
Today I took my '99 XJ x308 from the service, The broken secondary tensioner in the right bank was replaced on the new one from SNG Barratt. When the old tensioner was broken, the chain jumped to one or two teeth, I don't know exactly, but it was a luck for me that pistons didn't strike valves. And also, when the tensioner was replaced and the chain was set in accordance to the marks, the "restricted performance" error disappeared! I don't know how these operations affected it.
Old Oct 26, 2018 | 06:44 AM
ericjansen's Avatar
Finished up the rear headrests, guess I succeeded ...
Project done!
Old Nov 2, 2018 | 10:51 AM
The Sovereign ( and I think the VDP seats ) model version for the X300 will not be so high up as the armrest has to come off for a cavity . If I can figure out how with the whole seat back removed from the car .
Only enough room for a short Champlain bottle
Old Nov 2, 2018 | 09:07 PM
ericjansen's Avatar
No idea why my (and some other) posts end up here in a discussion on airbags, it was posted in an other thread.
That said, my bottle is of 1/2 format, some crap from the Carrefour sold as a 3-pack.
Just for looks
Old Nov 17, 2018 | 02:59 PM
StagByTriumph's Avatar
Talking Finally got my lift cleared for my XJ8 work ...
Guess what I am doing?
The Wonderful all Plastic 4.0 liter Intake Manifold - prior to degreasing, cleaning and visual inspection (do you see any issues here?)
I was actually quite surprised at the ease of access and disassembly. While I am at it the thermostat housing gets replaced with the aluminum upgrade, replacing the Heater IN/OUT hoses.
Left side cams (shown here) in sync just like the right side (checked flats with a straight edge), and timing chains, guides and gears look perfect. With 106k miles I was expecting different, I am suspecting they have been replaced? Any suggestions to look for "While I am there?" waiting for my other parts to arrive?
So while I am there, replacing or fixing:
  • Obviously leaking Intake Manifold Gaskets with new
  • full inspection and seal up all glued on parts on the Intake Manifold
  • Reseal all TB flanges to Intake Manifold
  • Cam cover gaskets and o-rings sets New
  • VVT Solenoid gaskets New
  • Fuel Injector O-Rings (set of 3 o-rings each) New
  • Heater IN/Out hoses running under the intake New
  • Plastic Thermostat housing setup with all Aluminum upgrade New;
  • Thermostat - failsafe OE New
  • Upper Radiator Hose New
  • Lower Radiator Hose New
  • Thermostat housing to hose housing hose New
  • - already replaced
    • NGK Irridium plugs New
    • coils New
    • HO2 upstream and O2 downstream Sensors New
    • - already addressed these
      • part load hose
      • full load hose
      • Injector air flush hose
      • Throttle Body
      • MAF sensor (swapped with my 2000 XJ8 to confirm operation)
      • cleaned 8 injectors reverse and forward flush
Bore-scope check of each intake valve and valve seat.
Also a full compression check and leakdown test "while I am in there" to make sure all cylinders are uniform, valves /rings are sealing up.
Do some harness and electrical diagnostics / checking.
Fun for a weekend or two.
Cheers!
Old Nov 19, 2018 | 04:31 AM
Sean B's Avatar
Glen, while you're in there I would suggest changing the timing chain tensioners, they're the plastic version that the bottom picture shows.
The uppers, lowers and guides are plastic and do fail leading to a new engine in the worst case, lots of solid info on how to tackle it.
You will need to remove the fan assembly and timing cover on the front of the engine to access the parts that need replacing.
Old Nov 21, 2018 | 10:40 AM
Exclamation AJ27 X308 Intake off and "while I am in there tensioners?"
Sean,
Thank you for that observation. It is most likely a good idea while I am in there to do that ... Now to locate the best price / availability kits for that part of the project.
I'll search the forums .
side note ... I'm not quite sure how my first post went into X300 Airbags?? I had posted it in X308 What did you do with your 308 today I thought ... How do we move it back to X308?
Cheers!
Old Mar 6, 2019 | 10:11 PM
theswede's Avatar
What did I do with my JAG today??
Well, I finally come to shoot, and reassembled my fuel tank with an new BOSCH pump, all new hardware and new hoses etc inside the tank, all new stuff
And new quick connectors for the tank connectors/fuellines..
New K&N fuel filter..( and blow the old gunk out from the fuel lines, was old gasoline that smelled like turpentine and looked like old oil "goe"
The car had been parked for like 8 years?!
Got the tank back in the car, filled some fuel, and primed the lines
And to a surprise, she spun up! First time for me.. well spun and spun, kinda sputtered and so..
But at least she kinda run!
So how do I clean my injectors?
Any ideas/suggestions?
Old Jun 19, 2019 | 11:40 AM
AtraelyxVasser's Avatar
Replaced the missing headlight on Alice. Finally got word back on the insurance company repairing the rear end.
Old Aug 17, 2019 | 03:45 AM
dfieldsend's Avatar
Edited, sorry, wrong forum!
dwgates
Sep 1, 2018 07:50 AM
SkinnyLard
Aug 30, 2015 07:26 PM
J_B_1
Mar 28, 2015 07:20 AM
Road Racer
Oct 23, 2014 07:27 PM
BadCat
Feb 1, 2011 10:12 AM
