xj8 4.0ltr..stuck in P
Old Jul 26, 2014 | 01:38 PM
thejagman's Avatar
Angry xj8 4.0ltr..stuck in P
can any one help, my 1997 has been sat on my drive for 3 years..she was fine going into D as i have been testing the gears for most of the 3 years, but now she wont shift from P. i can shift from p into by using the manual override and the beep kick in and i can start her in N. but as soon i put her in P..then she is stuck
Old Jul 26, 2014 | 02:00 PM
I've moved your question from UK Region to X308 forum.
You'll get the combined brain power of members from around the World with the same model.
Old Jul 26, 2014 | 02:58 PM
Sean B's Avatar
After 3 years it might be seized brakes, either handbrake shoes, or pistons front and rear.
Does it go into drive/reverse?
Old Jul 27, 2014 | 03:40 AM
thejagman's Avatar
Default stuck in p
Yes it does go in D and R and all other gears and I can drive the car, but I can only do that by selecting the gears by using the gear shift interlock manual override. As soon as I put her back in P and then I cant move the selector without using the override.
I have checked and cleaned all four breaks.
Old Jul 27, 2014 | 03:58 PM
avt007's Avatar
Check the brake lights. The brake switch should cause the shifter solenoid to "clunk" when you step on the brake. Does that happen?
Also check fuse #12, LH heelboard, also fuses 5 and 7, same fuse box.
Old Jul 28, 2014 | 02:10 PM
thejagman's Avatar
Default stuck in p
Checked all the fuses u said to check all fine, but the brake lights do not come on when press the pedal.
Old Jul 28, 2014 | 02:24 PM
avt007's Avatar
In that case the most likely culprit is the brake switch itself. JTIS says it's "adjacent to the brake pedal mounting assembly".
Old Jul 28, 2014 | 04:37 PM
thejagman's Avatar
Default brake switch
Yes I think u r spot on...have read other post on the subject and one member has posted a step by step guide.
Going to try it on sat and see if that fixes the selector problem.
Thank u guys
magmedia
Oct 8, 2015 03:28 PM
freddieg
Oct 6, 2015 11:23 AM
mat32essex
Oct 3, 2015 04:12 PM
kingdom worker
Oct 2, 2015 05:43 AM
donald ebanks
Sep 30, 2015 07:08 PM
