XJ8 engine noise
Old May 3, 2019 | 06:35 AM
dangelous's Avatar
Default XJ8 engine noise
Any ideas?
Old May 3, 2019 | 06:36 AM
dangelous's Avatar
For some reason it’s not letting me upload my video. I’ll try again
Old May 3, 2019 | 09:40 AM
dangelous's Avatar
Default Engine noise take two!
Ok here we go again.
started last week, any thoughts? She’s going in for the cam cover gasket replacement when I’m back from holiday, made this noise when I picked her up from the mechanic who did the wheel bearing and he wasn’t sure what it was. Any thoughts chaps? Link below.
Dan.
Old May 3, 2019 | 10:12 AM
Highhorse's Avatar
Timing tensioners probably...when you remove the cam covers, you'll be able to identify it immediately. If you have burnt orange plastic tensioners, they will need replaced. If you have silver metal finish, they've been done, but don't discount they may have gone bad, check the chain tension. I put new ones in mine and about a year later, one of my neoprene guide caps came off and I had to replace the tensioner again.
Old May 3, 2019 | 10:36 AM
Jhartz's Avatar
First, go buy a mechanic's stethoscope. Then troll around to find the source of the noise. Sounds like maybe water pump or belt tensioner -- but need to know front, back, left, right, up, down . . . ? Lots of possibilities. Sort of surprised the tech wouldn't check it out. Just be careful where you put the sound lead -- too close to the whirring parts and you could get hurt; be very careful not to touch those plastic pipes going to the radiator -- they redefine the word 'fragile.'
Second, pull the cam covers and determine whether you have the newer secondary tensioners -- this is critical!
Old May 3, 2019 | 10:37 AM
dangelous's Avatar
It’s 2001 so it should have the metal tensioners, it seems to be coming more from the middle of the engine not the front too.
Old May 3, 2019 | 11:00 AM
King Charles's Avatar
Not necessarily that goes according to your build date. Only the late 01's are covered & those are the 2nd gen tensioners @ that.
Old May 3, 2019 | 11:29 AM
dangelous's Avatar
well that would be just my luck!!! Thanks though!
Old May 3, 2019 | 11:33 AM
Originally Posted by test point
Look at the label on the driver 'B' column for the manufacturer date. Anything prior to Sept '01 came with plastic tensioners.
https://www.jaguarforums.com/forum/x...nsioner-47154/
Knowing's half the battle lol !
Old May 3, 2019 | 11:52 AM
dangelous's Avatar
haha Amen to that!!
LAjag
Jul 6, 2019 07:12 PM
RacingGreen
Jun 21, 2018 08:22 AM
wheelbrace
Feb 10, 2016 12:03 PM
bigcat777
Feb 8, 2015 09:11 PM
Drb007
20
Dec 15, 2013 01:39 PM
