xj8 suspension upgrade
Old Feb 16, 2010 | 02:28 PM
ricasso's Avatar
Default xj8 suspension upgrade
is there a stiffer spring/shock setup available for my '98 xj8 4.0L lwb, the ol'girl tends to wallow excessively on the curvy stuff,to the point of being scary, or would new standard items do the job (I dont know what it should feel like new!), would the xjr setup work?, BTW, im in the UK.
Old Feb 16, 2010 | 04:45 PM
H20boy's Avatar
if she's wallowing, more than likely the shocks are kaput! (<- my best german). Have an indy shop give you a 'professional' opinion, but that's my guess. Sway bar bushings may be contributing as well.
Does she bounce too much on straights, or just 'roll' in the corners?
Old Feb 17, 2010 | 01:05 AM
ricasso's Avatar
bit of both really, could be time for a complete overhaul of springs,shocks and bush's
Old Feb 18, 2010 | 09:12 AM
Viapa's Avatar
Yes. Mina Gallery suspension. I am in the process of ordering the Mina Gallery Suspension upgrade. It cost around $350 with previous purchases from Mina Gallery. I plan on giving my overall opinion of the suspension upgrade. I do know that it lowers the car 1.25 inches. www.minagallery.com
Old Feb 18, 2010 | 11:25 AM
stran0020's Avatar
please keep us updated! and if you will post before + after pictures!
Old Feb 20, 2010 | 10:56 AM
jaggachafen's Avatar
i Have springs from XKZ on my XJR and it works fine. But my car isn´t a LWB and i have the CATS suspension so it wasnt so bad to start with. But it became stiffer with the new springs thats for sure.
If you need new shock i would go for bilsteins and buy them for an XJR or sports modell then they will be stiffer
Old Feb 20, 2010 | 03:11 PM
ricasso's Avatar
Yes, I think the xjr setup (shocks and springs) is the way to go, can anyone confirm that it would fit?
Old Feb 20, 2010 | 07:16 PM
yes it will fit. Do you have CATS or not on your car?
Old Feb 21, 2010 | 11:27 AM
ricasso's Avatar
No, im quite sure its just the standard setup,would it still work?
Old Feb 21, 2010 | 05:06 PM
es if tou dont have CATS just u sport without CATS. its alot cheaper aswell. an easy way to spot if you have CATS is to look at the top of the frontdamper (easily spoted under the bonnet) If there are wires goin in to the top of the damper you have CATS if it doesn´t then well you don´t have it
Old Oct 2, 2022 | 10:18 PM
Jajiyojo's Avatar
Default I also have some questions
Kind of late to the party. Don't even know if yall still look at this but I'm trying to upgrade my suspension to a more firm racing spec and idk where to look or how to look. I own a 98 jaguar xj8 and I just need help
Old Oct 3, 2022 | 10:27 AM
Sean B's Avatar
It depends where you are in the World - location?
UK-Europe there are the factory Jaguar XJR options, Sport and Supersport springs, dampers, AR bars, and bushes can all be added to an XJ8. Hardly racing spec, but an improvement nonetheless.
USA - not certain but the sport option was only available on the XJR? (look at forum ads with XJR's getting parted?)
There are tuning houses out there that offer packages, someone with aftermarket kit on here may help.
Old Oct 3, 2022 | 04:15 PM
vincent661983's Avatar
powerhouse UK
Old Oct 4, 2022 | 06:51 AM
RandyS's Avatar
It is hard to build a heavy Jaguar to "racing" spec, however I am certain that
there are those who will try.
Sentinelist
Jun 14, 2015 02:36 PM
David Lawson
Apr 21, 2013 05:00 PM
MoscowLeaper
Apr 4, 2013 12:41 AM
akgambino
Jul 8, 2012 03:18 PM
chknhwk
Apr 8, 2012 04:30 PM
