XJ8 Trunk Button
Old Apr 20, 2015 | 01:45 PM
aregg's Avatar
Default XJ8 Trunk Button
Lot of threads on the trunk button not working but mine is very unusual.
It appears as if the system goes into Valet mode and when you press the button on the trunk it will not open.
However I can open the trunk with the button inside the car, with the remote, or the key.
If I disconnect the battery for a few minutes to re-set, it starts working but then at some point the same story.
Any idea's? not a major problem just the fact that something does not work right bothers me.
Old Apr 20, 2015 | 02:23 PM
retromotors's Avatar
Have you tried a hard reset?
That's where you disconnect the negative battery cable, then hold it in contact with the positive battery cable/post for about 30 seconds.
That seems to straighten out a lot of problems with these cars.
Old Apr 20, 2015 | 02:57 PM
Sean B's Avatar
There's a bunch of wires connected to the right hand trunk lid hinge, some of these run the lights and lock, have you read about these wires breaking as they work harden over the years?
I located an earth cable in this bunch that had snapped inside it's shroud, a fast solder and shrinktube job and the lock button works as it should.
Old Apr 20, 2015 | 05:45 PM
aregg's Avatar
Sean, the car has very little milage and very little use so the likelihood of the wires breaking are less but when I do a reset it starts working for a while and I assume broken wire(s) could not be it.= or very unlikely.
Old Apr 20, 2015 | 05:47 PM
aregg's Avatar
Retromotors thanks no I simply disconnected the negative. Will try the hard reset and see.
Old May 11, 2015 | 12:00 PM
aregg's Avatar
Well the answer was damage to the wiring loom and a razor cut that caused intermittent function. Both the wires to the button were cut through cleanly and another had the insulation cut a little but nothing more. The culprit is the plastic cover that fits on the right hand hinge. At the extreme end where the wires would bend as you closed the trunk lead the plastic had a razor sharp burr inside
. I went a little further and reworked that end and again made sure it was clean and no chance of anything cutting through the loom and the wires.
Old May 11, 2015 | 06:07 PM
ericjansen's Avatar
Thanks Sean B
dsnyder586
Dec 29, 2024 07:39 PM
rentzoo
Nov 10, 2015 04:56 PM
findre
Sep 10, 2015 05:46 PM
al_roethlisberger
Sep 9, 2015 09:14 PM
prettydaim
Sep 7, 2015 05:16 PM
