XJ8 X308 Upper Sump Removal.
Old Apr 26, 2016 | 02:56 PM
Daimlerdave's Avatar
Default XJ8 X308 Upper Sump Removal.
Doe's anyone know if this is an engine out job or if it is possible to do by loosening some of the engine mounts and jacking the engine up a bit?
Dave
Old Apr 26, 2016 | 04:45 PM
Japawels's Avatar
I have not tried it myself but the manual says it's possible.
Attached Thumbnails XJ8 X308 Upper Sump Removal.-u1.jpg   XJ8 X308 Upper Sump Removal.-u2.jpg   XJ8 X308 Upper Sump Removal.-u3.jpg   XJ8 X308 Upper Sump Removal.-u4.jpg
Old Apr 26, 2016 | 08:03 PM
Addicted2boost's Avatar
If your trying to do it in your garage, that's gonna be quite a chore. Personally, I've never tried it. By the time you manage getting to it, you're either gonna end up removing the subframe or pulling the engine. I'd recommend doing the engine pull. Why are you wanting to pull the bed plate off?
Old Apr 27, 2016 | 10:58 AM
It's damaged, something went through the front end of the car. I have a new one all ready to be fitted.
I just have to remove it, there is zero give in the engine mounts so I figured i would try to jack the engine up off the mounts and slide it across the subframe.
Old Apr 27, 2016 | 11:00 AM
Thanks for the help by the way its really appreciated.
I'm used to building engines but not had a XJ8 308 apart before.
Old Apr 28, 2016 | 04:02 PM
Ok i have done it! Had to undo the ns steering rack bolts and jack the engine off its mounts but otherwise all ok!
Old Apr 28, 2016 | 06:32 PM
motorcarman's Avatar
thekiltedwonder
Apr 27, 2016 06:11 AM
jaguarguy13
XJ40 ( XJ81 )
Apr 26, 2016 11:43 AM
darrhel
Apr 23, 2016 06:58 PM
Forcedair1
Apr 21, 2016 10:21 AM
