XJR bucked on me twice and went to restricted mode.
Old Feb 28, 2008 | 06:04 PM
Donzi's Avatar
Default XJR bucked on me twice and went to restricted mode.
2000 XJR, 65k miles. Car is new to me, had it for 1 week.
Here is what happened.....Trans in sport mode, under moderate acceleration from about 55 mph.
It bucked on me fairly hard twice, I backed way out of the throttle.
Performance restricted mode on message center, check engine light cameon.
Message went away within 10 seconds and ran normally instantly.
Drove it another 20 miles home and never did it again.
it runs normally now, but check engine light is still on.
60K service was done on it 1 year ago by dealer.
It drove purrrfectly last week for 130 miles when I drove it home after I bought it.
Any ideas? Also is there a scan tool that I can buy/afford that could be usefull?
Ted
Old Feb 28, 2008 | 06:52 PM
jag_genius's Avatar
Default RE: XJR bucked on me twice and went to restricted mode.
could be a throttle problem..
jag_genius's Avatar
codes will have to be read for further diag.
Old Feb 28, 2008 | 06:59 PM
Donzi's Avatar
What can I buy to read the codes? Is it an OBD II ?
Old Feb 28, 2008 | 07:02 PM
jag_genius's Avatar
some auto zone can read it for free... or a jag dealer...
Donzi's Avatar
OBD II ?
Old Feb 28, 2008 | 07:07 PM
jag_genius's Avatar
yes, but not all readers can give full description or read abs or SRS systems
Old Feb 28, 2008 | 07:08 PM
Donzi's Avatar
Can you reccomend one please?
Old Feb 28, 2008 | 07:23 PM
jag_genius's Avatar
ive never used aftermarket readers i have the realIDS .. it's on my laptop right now.
Old Feb 28, 2008 | 07:43 PM
FactoryJaguarTech's Avatar
Same here. Did you spring for the VCM and cables?
Old Feb 29, 2008 | 12:05 AM
NorCalDiesel's Avatar
Us mere mortals have to settle on an AutoEnginuity scanner. you'll have to pay for the scanner itself as well as the Jaguar bundle. It will cost you around $350.00 or $400.00 total. I have one and use it for my Ford Diesel and my Jag XJ8. If you get the Jag bundle it will read everything frp, Powertrain to SRS and ABS. Without it you're at the mercy of others.
Old Feb 29, 2008 | 04:56 AM
The bucking thing could also be just bad gas? If car was onlybought last week, could be sucking through some old gas.
Also, replace fuel pump relays. Seen them get sticky.
Old Feb 29, 2008 | 06:38 AM
Donzi's Avatar
Will do. thank you all!
Old Feb 29, 2008 | 06:52 AM
jag_genius's Avatar
i dint spring for them i got them for free...
Old Feb 29, 2008 | 04:58 PM
Donzi's Avatar
Created new post. Thanks
Old Mar 1, 2008 | 09:08 AM
Donzi's Avatar
Would that also explain the slight stumbling at aorund 3000 rpms......but clears out
when I really get on the throttle hard?
Old Mar 3, 2008 | 07:21 PM
Donzi's Avatar
Problem fixed, a new MAF sensor did the trick.
Thank you all for your help!!
Old Mar 3, 2008 | 07:40 PM
ibjags's Avatar
maf sensors are pretty common fault for lean codes if there arent any vac leaks found first
Old Mar 7, 2008 | 02:46 PM
skanoski's Avatar
I got a cheap OBD II for about $50 on ebay, and it's good enough to read and clear codes. it also gives some live data as well. For you purposes, you probably don't need to spend more than this. There's a bunch of cheapos on ebay that may suffice.
xjrjag
Oct 24, 2024 03:09 PM
D.K
Dec 10, 2023 02:05 AM
Forcedair1
Feb 19, 2020 01:51 PM
kevo
Sep 8, 2015 09:45 AM
XFR_Gold
Sep 2, 2015 12:24 PM
