xjr heater hose leak can anyone help pls
Old May 8, 2012 | 12:46 PM
xjr4life's Avatar
Default xjr heater hose leak can anyone help pls
hi everyone i have a slight leak it seems to be the heater hose however the hose is dry but where there is a black plastic connector/adaptor it seems to be wet and dripping out of there
i am trying to attach a picture sorry you may have to zoom in to read what i labelled i apologise i have forgotten how to post a picture on here properly
is there anyway of getting the adaptor/connector on its own or do i have to buy the whole hose etc
thanks again
Attached Thumbnails xjr heater hose leak can anyone help pls-img-20120508-00048.jpg
Old May 8, 2012 | 02:23 PM
Brutal's Avatar
Theres a oring seal in ther. And ive heard of people cutting it off and refitting. But really! Fix it correctly with a new heater hose matrix. Its a pia but if thats leaking the hose splitting open will be soon behind and that wont be a leaker but a gusher. Leave the reservoir cap loose to not build pressure and make it worse till you get to it.
Old May 9, 2012 | 05:12 AM
Megawatt's Avatar
If you are going to be working down in that area... Strongly recommend looking at the Transmission Electrical connector mounted on bracket top of Tranny bell. This is a lot easier to get to + clean corrosion/contact cleaner out of it when Intake + other stuff out of the way. (this was the root problem of my intermittent gearbox faults)
Old May 9, 2012 | 05:52 AM
xjr4life's Avatar
Default thanks brutal
thanks brutal yes i'm going to get that pipe changed iti s item number 6 on the pic attached sorry you may have to zoom
do you know what the book time is to do that job is it about a hour or more? i also ordered a gallon of the pink coolant hopefully all goes well
regards
File Type: doc
Old May 9, 2012 | 07:57 AM
Brutal's Avatar
yes 6, take off the throttle body for better access and 3+hours depending
Old May 10, 2012 | 08:07 AM
xjr4life's Avatar
thanks thats definately gonna hurt the pocket @labour time per hour anyway guess that hose has lasted 12 years.....
Old May 10, 2012 | 08:48 AM
Dan R's Avatar
Had the same problem. The Norma connector fell apart as I tried to disconnect it. Cut out the connector and spliced in some heater hose with male-male connectors. There are descriptions of this on the board.
The repair has lasted two years so far.
Old May 10, 2012 | 11:08 AM
xjr4life's Avatar
exactly it seems to be the connector its leaking out from, the rest of the hose seems dry thanks i will have a look for that thread at £70+ just for the hose and then 3 hours labour or so i would ideally like a repair but thinking after 12 years i think that rubber hose maybe a bit weak too its also a shame they dont sell that connector on its own...think its best i just put a new one least that hose will be ok for the next 12 years i hope
Old May 11, 2012 | 06:02 PM
xjr4life's Avatar
Quick update new heater hose put in old coolant replaced with fresh red jaguar coolant and brake fluid drained and replaced with fresh mobil dot 4 all in for £208 thanks to my excellent jag specialist mechanic I am pleased with the clean work and price thanks everyone for all your help and info
clubairth1
30
Sep 3, 2025 04:38 PM
dsnyder586
Dec 29, 2024 07:39 PM
Bcrary3
Feb 21, 2023 04:29 AM
02jagstype
23
Oct 23, 2022 07:03 PM
