XJR transmission issues
Old Apr 22, 2008 | 01:02 PM
tr_car_nut's Avatar
Default XJR transmission issues
The transmission on my 2000 XJR is acting very oddly these days. Shifting is very poor when first driving the car in the morning. Shifting from Park to Reverse there is a delayed reaction before the car goes into gear. Also there are several warning lights on the dash that are lit up such as the anti-lock brakes andtraction control. Not sure if the warning lights are related to the transmission or if that is some other problem. Car appears to drive fine once it warms up but the warning lights stay on untill the car is shut off. Starting the car again will often clear the warning lights.
2000 XJR, 70K miles
Old Apr 23, 2008 | 09:55 AM
FactoryJaguarTech's Avatar
Default RE: XJR transmission issues
The abs light is not related to the transmission. You would need to get codes read to be sure what the fault is. We could all guess on here, and be way off. Need the codes to tell you for sure.
With the transmission, there is a bulletin for supercharged cars, to replace the transmission control module. I think. It may be for the XKR. I will research it and repost.
EDIT - The TSB is for normally aspirated XJ/XK Vin A00083-A30644 and F00103-F59525
Sorry for the confusion.
Old Apr 23, 2008 | 03:51 PM
XJR has a dipstick hole. You just need to have the special MB tool to check it.
Old May 5, 2008 | 07:22 PM
jag_genius's Avatar
lol very expensive fluid
Forcedair1
Sep 8, 2025 01:57 PM
JarodL
Mar 7, 2024 01:39 AM
Raul Lara
Sep 14, 2015 07:31 PM
Raul Lara
Sep 2, 2015 05:23 PM
