XJR VVT carrier removal
Old Apr 26, 2015 | 04:57 PM
Zues's Avatar
Default XJR VVT carrier removal
Hey guys, did some searching but could not get an answer. Looking to eliminate the vvt carriers from a s/c engine. Im wondering if the oil feed
needs to be plugged. If air is blown into one head it comes out the other, but im not sure if it goes anywhere else.
Old Apr 26, 2015 | 08:36 PM
motorcarman's Avatar
THERE IS NO VVT ON THE 4.0 S/C ENGINES!!!!!!!!!!!!!!!!!
bob gauff
Old Apr 26, 2015 | 08:39 PM
Zues's Avatar
I realize that. However the carrier is still there. Im wanting to get rid of it but im not sure what oil passages i may be altering.
Old Apr 26, 2015 | 09:49 PM
Zues's Avatar
I know sean b has had some experience, I wonder if he is on?
Old Apr 27, 2015 | 06:22 AM
Sean B's Avatar
I don't understand what you mean by carrier?
Old Apr 27, 2015 | 10:54 AM
Zues's Avatar
The bracket that the selenoid sits in. A couple of your posts explain plugging the passage way that would feed into the bracket on n/a cars. On a s/c motor, is that same passage way an active oil feed. If air is used in one passage way it comes out the other passage way on the other head. Is oil being fed through that passage from anywhere else on a s/c motor. In essance can i simply toss the bracket in the trash?
Old Apr 27, 2015 | 01:57 PM
Zues's Avatar
Small bump
Old Apr 27, 2015 | 05:25 PM
andrew lowe's Avatar
What engine do you have? AJ 26 SC or AJ 27 SC ?
What year is your car ?
My 98 XJR do not have those carriers, the X308 JTIS do not show those carriers on an SC engine.
Have your heads been swapped for NA heads at some point?
Old Apr 27, 2015 | 06:28 PM
Zues's Avatar
Aj26 98 sc
Old Apr 27, 2015 | 06:37 PM
I have just repaired 2 S/C engines in the last few weeks (cylinder head R&R). There is no VVT solenoid bracket on the S/C engine.
Maybe someone installed NA heads on the S/C engine and did not want to plug the oil passages?????
You do realize that the passages need to be plugged??????
The TSB shows the location of the plug and description on how to remove but it sounds like you need to INSTALL!!!!!!!!!!!!!!!!
bob gauff
File Type: pdf
Old Apr 27, 2015 | 09:11 PM
Zues's Avatar
That would be pretty strange. I feel as though I have seen this before on the early s/c cars. Perhaps i'm wrong. Well ill order some plugs, hope they are available and easy to install.
Old Apr 28, 2015 | 12:06 PM
Zues's Avatar
Having trouble finding the plug. Is this something you can get seperatly?
Old Apr 29, 2015 | 09:42 PM
The plug is NOT sold by Jaguar. It was installed and was meant to be removed if necessary. There was a discussion on this subject a few months ago and I think someone tapped a pipe thread and installed a plug.
bob gauff
Old Apr 29, 2015 | 11:40 PM
Zues's Avatar
Looks like ill be doing the same. Thanks Bob for the knowledge.
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
danke
Mar 3, 2016 10:57 AM
philwarner
Sep 6, 2015 11:10 PM
AL NZ
Sep 4, 2015 08:39 PM
