XJR Wheel size
Old Oct 7, 2013 | 06:17 AM
dc4prez's Avatar
Default XJR Wheel size
Hi all
does anyone know what is the largest rim and tyre combination I can fit under a "99" XJR
The brakes are big, but not Brembo's
I would like to put 285/35 X 18 tyres on 9.5" rims,
has anyone done this or know if it is possible.
Old Oct 7, 2013 | 08:50 AM
vincent661983's Avatar
i have 20 inch Senta wheels on my XJR(X308) now
Old Oct 7, 2013 | 09:52 AM
Cabezagrande's Avatar
I am currently running 18x9.5 Corvette wheels on all four corners on my 2000 XJR, with 275/40/18 tires on the back and 265/40/18s on the front. The rears fit fine after a small (3mm) spacer and removing the rear bump stops. The fronts are very tight, but still fit with a 3mm spacer. 285/35s should fit the rear just fine with careful offset choice, but the fronts will be very tight. You'll likely have to clearance the inner wheel well liner slightly.
Old Oct 7, 2013 | 11:54 AM
Badbenz94's Avatar
Do you have any pics? What about bolt pattern and hub size?
Thank you,
Chris
Old Oct 7, 2013 | 12:38 PM
I'll try and find some pics tonight. But the X308 is on the 5x4.75/5x120.7 pattern, same as older Chevys and the Corvette through today. The only thing I had to do to fit them was that the center bore needed to be expanded slightly, as the Jag has a huge hub diameter at 74mm, and the Vettes are at 73mm. I had it done at a local machine shop for like $25 a wheel.
Old Oct 7, 2013 | 01:25 PM
Badbenz94's Avatar
Thank you! I thought I heard that...Im looking to get rid of my chrome asteroids and want something different. Looking forward to seeing pics!
Chris
Old Oct 8, 2013 | 05:01 AM
dc4prez's Avatar
Thanks for that, I like the idea of Vette wheels, lots of choices,
Old Oct 8, 2013 | 05:44 AM
Peterch's Avatar
Default XJR wheels
XKR wheels fit nicely 1" wider at rear.
285 35 18 rear
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
hunter34
19
Sep 14, 2022 11:09 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
