XJR/XJ8 wheel interchangeable?
Old Mar 27, 2017 | 09:46 PM
dmpsqrd's Avatar
Default XJR/XJ8 wheel interchangeable?
It's a dumb question...no a REALLY dumb question. Is a stock 18x8 308 XJ8 wheel interchangeable with those on an XJR? Just bein' careful here...once bitten...
Old Mar 27, 2017 | 10:12 PM
grandell's Avatar
XJ8's didn't come with 18's.
But yes, they'll fit.
The only reason these wheels wouldn't be interchangeable is if smaller XJ8 wheels (eg 16's) don't clear the XJR's larger brakes. The rest of the specs PCD, offset, centrebore) are all the same/interchangeable
Old Mar 27, 2017 | 10:58 PM
dmpsqrd's Avatar
Thanks...I was worried about the offset...I need a new wheel to tide me over until I can get to North Carolina to pick up a set of Asteroids- I cracked a wheel which is not repairable and the donut spare, quite frankly, puts me straight on the ledge. This wheel is in a local yard , is definitely a Jaguar 18x8, but marked as coming from an XJ8....
Old Mar 27, 2017 | 11:15 PM
dmpsqrd's Avatar
Default Mystery solved
Yard had the VIN from the donor....came from an XJ Sport...
Old Mar 28, 2017 | 01:13 PM
Stu 1986's Avatar
Wheels off and XJ40 and X300 will fit the X308 too as long as you don't have the big brakes.
The wheels on my XJ are 18 inch intended for an XKR, they are 8J at the front and 9J at the rear. The first owner paid a lot of money for them when the car was new, I've just had them refurbished and I'm pleased with the results.
Old Mar 28, 2017 | 04:43 PM
80sRule's Avatar
Which ones? Double Fives?
A user on here, ericjansen? (sp?) has them and they look good on his XJ.
Old Mar 29, 2017 | 02:45 AM
Stu 1986's Avatar
Flutes, have a look on my thread there's photos from when I had them refurbished the other week.
https://www.jaguarforums.com/forum/x...vation-166459/
Old Mar 29, 2017 | 04:17 AM
Addicted2boost's Avatar
I had the 18" Pentas on my 98' XJR but, when I got the car they had 3 bent wheels.
We were given a parts car that had these 16" crown wheels on it and so I took them off and had them powder coated. This car came with the standard XJ8 brakes on it so they cleared the brakes with the smaller wheels.
