ZF 5HP24 weak points for high torque engines
Old Mar 25, 2016 | 06:29 AM
Britax's Avatar
Default ZF 5HP24 weak points for high torque engines
What are the true weak points of the 5HP24, if you exclude the scored pressurevalve which cause pressurespikes that break the A clutch drum, and the failed C drum bearing which cause the A drum Oring to fail.
Lets say you put a 500hp 4.2 in front of this gearbox, what part of the gearbox is likely to fail?
(Except for the fact that you have to deal with extra cooling of the oil)
Old Mar 25, 2016 | 11:50 AM
Addicted2boost's Avatar
I can't realistically answer your question, but I can tell you that if you do that, you will need the largest externally mounted transmission oil cooler you can fit in front of the condensor.
littlelic69
Apr 9, 2016 05:01 AM
John Doe
Mar 26, 2016 08:51 AM
jaguar0206
Mar 23, 2016 03:39 PM
Wide_Tyres_2
Mar 22, 2016 09:02 PM
JRR705
E type ( XK-E )
Mar 19, 2016 09:03 PM
