ZF5HP-24 Transmission fluid
Old Mar 24, 2018 | 06:41 PM
Carnival Kid's Avatar
Default ZF5HP-24 Transmission fluid
Okay, I've researched this up the ying-yang, but I don't seem to find a positive answer.
Apparently the original transmission fluid in our X308 ZF5HP-24 automatic transmissions was Esso LT-71141, a semi-synthetic fluid.
1) Is this still available (Esso became Mobil which became Exxon ......or something like that).
2) If Esso is not available, what should be used?
I'm having the Transgo mod done soon and wanted to be sure they use the "correct" fluid.
Old Mar 24, 2018 | 07:20 PM
RJ237's Avatar
You can always use the jaguar fluid, but many of us passed on that because of the cost. Other fluids meet the spec. and I for one, don't think there's magic involved.
I used Castrol European in my 97 for 15K mi without a problem after changing the main pressure valve for the ZF upgrade.
Old Mar 24, 2018 | 07:25 PM
harvest14's Avatar
I ordered off of eBay when I serviced mine a few years ago. Here's a couple of current links to the type of fluid I ordered. I drove the car another 10,000 miles after the service without a hiccup.
https://www.ebay.com/itm/ZF-LIFEGUAR...aIpmHA&vxp=mtr
https://www.ebay.com/itm/Audi-BMW-Ja...BZHaFX&vxp=mtr
It appears to be made by the same company that made the transmission.
King Charles's Avatar
Febi Bilstein ATF Transmission Fluid is Esso LT 71141 equivalent & fairly priced.
https://www.ebay.com/itm/5-Liters-AT...-/361447478663
Old Mar 24, 2018 | 08:06 PM
yeldogt's Avatar
The lifeguard is the OE fluid ... I believe the authorized dealers of the rebuilt have to use it.. That said ...... Febi most likely made it.
Febi makes great stuff
Old Mar 25, 2018 | 10:34 AM
Daim's Avatar
I only use Mannol AG52.
magnum454
Mar 21, 2018 10:01 AM
BKSinAZ
Feb 21, 2015 02:02 AM
rainbowboy
Sep 9, 2013 12:48 AM
blackwolf560
Feb 16, 2012 07:51 PM
jrhalcomb
Jan 16, 2009 10:49 AM
