XJ40 ( XJ81 ) 1986 - 1994
***Help with identifying a part*** RESOLVED
Old Aug 25, 2023 | 01:53 PM
etaent's Avatar
Arrow ***Help with identifying a part*** RESOLVED
Hey guys. I have a power steering leak coming from the front and narrowed it down to this part that is installed inline on the hose that goes to the power steering reservoir. I believe its a power steering fluid filter but I am not sure and I am also not sure where to get one. A google search yielded more confusion than understanding since I did not see any that looked like mine. Appreciate the help in advance guys!
Old Aug 25, 2023 | 04:48 PM
jerry_hoback's Avatar
Hi, just to clarify- at the left or lower of the pic- is that the a/c compressor?
Old Aug 26, 2023 | 08:09 AM
motorcarman's Avatar
If you have DELETED the SLS rear hydraulic dampers and fitted standard units, then you don't need the pump on the front of the engine.
I removed ALL the pump, valve block and hoses from the system and fit new PS feed hose and return lines.
You can then use DEXRON ATF for the fluid.
Old Aug 28, 2023 | 09:40 AM
etaent's Avatar
Thanks for the responses guys! I believe the compressor is on drivers right of the part. It is connected to what looks like a the pump that motorcarman mentioned. I took the old one off and it looks like an inline power steering filter so I just replaced it for now with a new aftermarket one from autozone. So far no issues but most importantly no leaks! I used Edelmann Elite Power Steering Filter Part number 70699 and changed the connectors to 3/8 inch to fit the hoses. I have included the link below to the piece in case anyone needs it!
https://www.autozone.com/filters-and...B&gclsrc=aw.ds
skizot
Feb 18, 2023 08:31 AM
cyber3d
Aug 11, 2017 03:57 PM
BadDog
Nov 3, 2013 02:00 PM
Jag_man81
Dec 6, 2011 01:41 PM
Straight6DOHC
Feb 7, 2011 06:57 AM
