XJ40 ( XJ81 ) 1986 - 1994
ABS Failure/Low Pressue Light on XJ6
Old Jun 14, 2008 | 12:49 AM
JagtechOhio's Avatar
Default RE: ABS Failure/Low Pressue Light on XJ6
If you seek out and find a local mechanic who can answer your questions, you will be assured that these two separate issues are not terribly serious...and you'll know who to consult when the next problem with this model arises. There are many, but the drivetrain is basically very reliable.
Old Jun 14, 2008 | 01:29 AM
Posting has been difficult here, so mine are currently short and choppy. That would have to be an exceptionlly nice, low mileage '88 for it to demand that price. They are still around, but rare. The only other advantage in buying an '88, more relevant today then ever: the early cars were fitted with a lower compression engine that runs just fine on regular 87 octane gas.That was the last Jaguar built to be able to make this claim.
Old Jun 14, 2008 | 04:54 PM
You're quite welcome, and your courtesy is greatly appreciated. XJ6 engines in that mileage range will likely need a head gasket soon, unless already replaced.
Old Jun 14, 2008 | 04:56 PM
The '88 Xj6 engine is reliable, but nothing lasts forever. Head gasket $800- $1000.
Old Jun 14, 2008 | 04:59 PM
ABS overvoltage relay $90. Brake accumulator charge switch or low pressure switch, maybe $200 each plus one hour labor. Possible brake accumulator vessel, $300 plus 1/2 hour plus $20 for fluid,
Old Jun 14, 2008 | 05:01 PM
Those are the sort of repairs you might expect, pending diagnosis. Just from alot of past experience. Tell him "fix the brakes first, if I drive it and the problems are resolved I'll give you $2000.
Old Jun 14, 2008 | 05:03 PM
Sorry for the stuttering, I wrote long posts all week and watched them go "poof". Good luck, get in touch direct if your anywhere near Ohio.
Old Jun 14, 2008 | 05:06 PM
If you want other choices, I can put you in touch.
Old Jun 14, 2008 | 06:03 PM
There might be a guy named Bunyan, but I hear he can be a little heavy-handed at times. Paul, I think. Ax him anything!
Old Jun 14, 2008 | 08:13 PM
ibjags's Avatar
Jagwannabe
Sounds most likely to be the accumulator sphere
look online for an aftermarket
PM me, i can give you detailed diag for abs faults if your interested
rusty37
Apr 5, 2020 07:40 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
carcycle
Sep 7, 2015 04:14 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
innzane
Sep 2, 2015 10:08 AM
