XJ40 ( XJ81 ) 1986 - 1994
AC Crapped Out
Old Aug 17, 2014 | 06:53 PM
Roger95's Avatar
Default AC Crapped Out
Hi everyone.
On the way home from dinner tonight with the AC in my '90 Majestic keeping us cool it crapped out.
That's it nothing - no dash fans, no air flow; nothing. The fuses all appear OK and I am inclined to think that it's either the AC ECU P/N JLM2212 or the control panel P/N DBC 5844. Any advice?
Thank you all,
Roger
Old Aug 17, 2014 | 08:10 PM
Lawrence's Avatar
Originally Posted by Roger95
Hi everyone.
Thank you all,
Roger
First thing to check would be the micro switch on the control panel - $5 part from radio shack - good illustrated post in the archives on swapping it out.
Larry
Old Aug 17, 2014 | 08:35 PM
Rob Evenson's Avatar
Roger,
I just ran a search on ebay, no less than 18 DBC5844 were available, one was as low as $50 up to $200 for a never used (new) unit. I have two, one as a back-up in case the micro-switch Larry referenced decides to go.
If you get no response from the unit on any speed, replace the unit, if there is fan activity on the lower settings, replace the micro-switch. I have rarely, if ever, heard to the ECU being the problem....then again....it's a Jag.
Larry, correct me if I'm wrong, but I thought the micro-switch affected the variable fan speed settings. IIRC, the relays in the blower assemblies only know one setting, as in full power, and the micro-switch sent a variable voltage signal for the lower fan settings.
Old Aug 17, 2014 | 08:52 PM
Roger95's Avatar
Thanks Rob, great minds think alike! I just bought the EBAY NOS unit for $84.00!
Old Aug 18, 2014 | 12:08 AM
Lawrence's Avatar
Originally Posted by Rob Evenson
Roger,
You're probably right Rob, I assumed the micro switch ran the panel controls and I thought I read that if the panel is dead (no lights) then the switch had failed.
Back when I started rebuilding the climate control and a/c systems on my '94, I replaced the micro switch only to find out later that the switch issue only affects earlier MY panels.
all the best
Larry
Old Aug 25, 2014 | 06:14 PM
Roger95's Avatar
My problem was the micro switch in the control panel.
I bought a NOS control panel that was very reasonably
priced off Ebay and popped it in this PM.
I also bought the Jag micro switch kit P/N JLM11240 which I
will use to repair my original panel and I'll have a spare.
Old Aug 27, 2014 | 02:44 PM
Roger95's Avatar
Here we go again...! So my wife takes the Majestic this AM and when she returns she says "the AC isn't working honey".
What says I! Leaky hose. Hose P/N CCC5504 (special order) is leaking at the crimped fitting at the expansion valve.
So...I ordered three new hoses and a new receiver dryer along with new O rings for the service fittings on the compressor.
How often do I advise everyone to not cheap it out and replace everything
25 year old hoses may look good and not leak initially, but they won't last!
I should have known better.
boiler
US Southwest
Dec 20, 2025 12:38 AM
KidRock'n
Oct 28, 2015 06:14 PM
AnD3rew
Sep 26, 2015 06:06 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
Bcrary3
Sep 1, 2015 08:21 AM
