XJ40 ( XJ81 ) 1986 - 1994
alternative fuel pump
Old Aug 9, 2012 | 04:41 PM
roger ele969c's Avatar
Default alternative fuel pump
Hi all, pump is not delivering sufficient pressure. Can I just install one inline, without doing anything else, or what is involved ?.......Roger.
Old Aug 9, 2012 | 05:38 PM
MidwestJag's Avatar
Roger:
Sorry, I've been away for a while. What year is your car? Based on your question, I'm guessing '91 onwards... I've never heard about anyone adding an additional fuel pump to a car with a pump in the tank. And I'm guessing your question stems from not wanting to pull the tank for a proper pump renewal. Perhaps one of the techs will have a definitive answer. Meanwhile, I'm wondering if you've done a few of the basics: fuel pressure test, fuel filter change, fuel pressure regulator...
cheers!
Scott
Old Aug 9, 2012 | 07:07 PM
Hi Scott, Sorry I left out the basic information. Yes, 1993 VDP, I'm thinking of avoiding the 'tank pulling' joyful experience. Pressure at the rail is little more than a dribble, allowing the car to idle but nothing more.....Roger.
Old Aug 10, 2012 | 02:59 AM
Roger,
In a word, NO.
The fuel has NO way of getting OUT of the tank without that pump pumping it out. There is NO provision for a "gravity feed" from the tank, and to fit one would require the tank being OUT of the car, so nothing gained.
The tank out is not that bad, it looks worse than it is, and YES, many things need removing to do so, but it is methodical.
I had the X300 one out in about 2 hours the first time, and MOST of that was getting the DUMB fuel lines out of the bottom of the tank. The second time (new pump was noisy), it took less than 1 hour all done.
Old Aug 10, 2012 | 03:29 PM
Hi Grant, OK, out it comes then. That I'd just filled it up doesn't help but, it's gotta be done........Roger.
Old Aug 10, 2012 | 07:33 PM
Lumppy47's Avatar
Before going to the trouble of removing the tank I would replace the fuel filter,and check that the fuel lines are flowing freely.
Old Aug 10, 2012 | 08:59 PM
Thanks Lumppy, Now know it's not the pump' Recently changed filter so, I'm starting another thead on this......Roger.
Old Dec 18, 2012 | 10:53 PM
aldol's Avatar
Default it ought to work ok adding an online pump
if the current pump provides almost adequate flow and pressure, by adding an online pump now you allow your in-tank pump to pump against 14.7 psi negative pressure rather than 42 psi positive pressure required by the pressure regulator.
this difference of 55 psi will increase your pump output by about 50%
if the in-tank pump is a turbine pump .
Old Dec 19, 2012 | 03:23 PM
Hi aldol,
I was heading in completely the wrong direction. It turned out to be the crankshaft position sensor........Roger.
Old Dec 20, 2012 | 07:04 AM
mrtalkradio's Avatar
CPS will getcha every time, numerous posts on it in this section.
Old Apr 29, 2013 | 07:35 AM
johncvs's Avatar
Hello Roger,
is part of your user name (ELE969C) an old registration number for the UK ?
Regards, John
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
lovemyjag78
Sep 14, 2015 07:42 PM
Sprayall
Sep 3, 2015 07:49 PM
