XJ40 ( XJ81 ) 1986 - 1994
Battery drain
Old Dec 2, 2011 | 11:34 PM
gdstok's Avatar
Default Battery drain
I am having an issue with a fully charged battery running down in about 2 days. Have swapped a couple of known good batteries, and get the same result. Battery tested with 500 amp carbon pile tester, checks good.
I know that normal diagnostic process would likely be to remove fuses and replace one at a time measuring for draw, but this thing has so many fuses! Does anyone have an idea of most likely suspects? Where are the most likely sources, if ther are any, on these cars?
Any help or ideas would be greatly appreciated. Thanks.
Old Dec 3, 2011 | 01:01 AM
Jagfix38's Avatar
Check that the rear in cabin reading lights are correctly housed in the off position. Also check that the ignition is turning completely off with the key removed and that also goes for the door locks (there is a little electronic sensor in there that often gets stuck "on" with the key removed)
Old Dec 5, 2011 | 08:58 AM
gdstok's Avatar
The cabin lights are secure and off. I also noticed that I canno unlock the rear passenger door. Maybe that is staying engaged, but it doesn't unlock with battery removed either. I will check the door locks and the ignition switch as well. Thanks.
aholbro1
Dec 29, 2024 06:46 PM
lighterthanair
Sep 24, 2015 08:36 PM
puddled
Sep 22, 2015 03:57 AM
Charlene n John
Sep 14, 2015 10:08 AM
obwoodie
Sep 3, 2015 07:45 PM
