XJ40 ( XJ81 ) 1986 - 1994
Belt Removal Help
Old Jan 17, 2014 | 02:59 PM
Jag-GM's Avatar
Default Belt Removal Help
I need some step by step help and advice on a belt removal. I have attached some pictures of a belt I found deteriorating and I want to replace it before snapping as its begun to tear on the outer edge.
Essential could you explain exactly what it is? where might I find one to purchase (Vancouver area)? and most importantly how do I remove it?
Attached Thumbnails Belt Removal Help-dsc_0440.jpg   Belt Removal Help-dsc_0444.jpg   Belt Removal Help-dsc_0441.jpg   Belt Removal Help-dsc_0442.jpg   Belt Removal Help-dsc_0443.jpg
Last edited by GGG; Jan 18, 2014 at 03:24 AM. Reason: edit typo in thread title so it appears in searches
Old Jan 17, 2014 | 03:11 PM
Lawrence's Avatar
Hi, that's the air injection pump. The belt part number is EAC6335 not very expensive, (about $10) but you'll have to shop around to find one - try googling the part number and see what comes up.
cheers
Old Jan 17, 2014 | 03:21 PM
Jag-GM's Avatar
cheers
Awsome, How do I remove it? Tighter the than all hell...
Old Jan 17, 2014 | 05:21 PM
Lawrence's Avatar
Well I've never taken one off but looks fairly straightforward - in your pic #5, looks like you slacken off the air pump mounting bolts and move the pump towards the thermostat housing - with the belt now slack, you should be able to remove it. Install the new one then lever the air pump back into position and re-tighten the bolts - offhand, I don't know the correct belt tension but the spec is probably listed somewhere in Haynes?
cheers
Old Jan 17, 2014 | 05:52 PM
Lawrence's Avatar
here's a belt for around $7, it's in the states though ...(no affil)
1994 Jaguar Vanden Plas Accessory Drive/Serpentine Belt 10 X 580
Old Jan 17, 2014 | 06:51 PM
Jag-GM's Avatar
Thanks alot, picked one up from Lordco, only 16$ gonna take it up to the shop have mechanic use a tensioner to remove and apply.
Old Jan 17, 2014 | 06:53 PM
............ I don't know the correct belt tension but the spec is probably listed somewhere in Haynes?
Here's the Haynes section on belt replacement:
Attached Thumbnails Belt Removal Help-haynes_1.jpg   Belt Removal Help-haynes_2.jpg
silkcat
Jan 18, 2025 04:29 AM
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
hoodun
Sep 13, 2015 04:03 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
