XJ40 ( XJ81 ) 1986 - 1994
a/c compressor not clicking on
Old Jun 2, 2019 | 10:19 AM
pixiesjag's Avatar
Default a/c compressor not clicking on
1989 Xj6 Vanden Plas My a/c is not working and i don't hear the compressor turning on my a/c control just has a slide for temp setting from hot to cold ..as we're new to owning is there something i'm not doing right.. how do you set the temperature that you want..and are there any fuse's i should look for.....all fuses in all 3 fuse boxes are fine..are there fuses to the compressor and where are they located.. haven't tried jumping the compressor yet not sure if i want to do that with everything being so electronic...
Old Jun 2, 2019 | 04:08 PM
motorcarman's Avatar
There is a pressure switch on the back of the compressor (they are prone to LEAK) that will disable the clutch if the refrigerant pressure is low.
You can reach down, unplug and 'short' the switch connector to engage the clutch if that is the problem.
bob
Old Jun 2, 2019 | 05:43 PM
pixiesjag's Avatar
thanks i did jump at the relay an came right on so next is to recharge it
slownlo
Jun 10, 2017 08:12 PM
john_cook12
Aug 10, 2016 11:37 AM
silkcat
Jun 26, 2016 04:00 PM
maikal_0011
Aug 16, 2010 09:45 PM
Tony_H
Aug 7, 2010 09:37 PM
