XJ40 ( XJ81 ) 1986 - 1994
Cheap crank position sensor on ebay
Old Aug 22, 2021 | 04:33 PM
JensenHealey's Avatar
Default Cheap crank position sensor on ebay
My MY94 XJ6 is currently not starting (it just chuffs when I turn it over with the key) so I am shopping around for a CPS to try and as usual I see new ones are in the $200 - $250 range. However I see the following listing on ebay for about $30 with free shipping.
https://www.ebay.com/itm/173999999989
This part at the CPS end looks like it might fit but the wiring connector on the other end looks totally different. It is a three wire sensor instead of the two wire sensor used on the X300 cars.
Has anyone here ever used one of these aftermarket CPS parts? If so how did you wire it up?
Here are some photos from the listing on ebay
Non-OEM CPS
Non-OEM CPS sensor wire end
Non-OEM CPS sensor - sensor end
Old Aug 22, 2021 | 09:25 PM
Lawrence's Avatar
Doesn't it look a bit shorter and fatter than OEM to you?
Maybe it's the pic, but sure looks short to me ..I'd ask the seller the dimensions if I were you.
Larry
Old Aug 22, 2021 | 09:28 PM
Don B's Avatar
Hi Steve,
I don't have any experience with those inexpensive crank sensors, but it shouldn't be difficult to wire it to the electrical connector from your old CPS. One of the three wires on your old CPS is a shield, and that is probably true of the new CPS also, so you just have to figure out which wire is the shield, and whether the polarity of the other two wires matters, which you can determine by simple trial and error.
The one thing that catches my eye is the short length of the barrel. For comparison, here are photos of the CPS on our '93 in the stock bracket and in Andy Stoddart's timing advance bracket:
Cheers,
Don
Old Aug 22, 2021 | 11:52 PM
stran0020's Avatar
You can get an aftermarket CPS sensor on sng Barrett for $55. I believe you can find the same CPS sensor on aliexpress for like $10 but I can’t seem to find it now and the shipping would prolly take awhile
Old Aug 24, 2021 | 04:34 AM
Sovejag13190's Avatar
Salut vous avez ce capteur sur aliexpress CPS 1990/1997 or HERE
Old Aug 24, 2021 | 08:40 AM
Don B's Avatar
Marc.
Ces vilebrequins les capteurs semblent être plus corrects que celui de la photo de Steve.
Those crankshaft sensors do appear to be more correct than the one in Steve's photo.
Merci,
Don
Old Aug 24, 2021 | 10:24 AM
Lawrence's Avatar
Yup. Agree with Don, the sensors in Marc's links look right and are definitely the right price!
I just might order one myself for a spare.
Larry
Old Sep 1, 2021 | 07:47 PM
Those are both two wire sensors for a X300 car. The XJ40 crank sensor is a three wire unit.
The wiring plug is totally incorrect for the XJ40 wiring harness.
Old Sep 1, 2021 | 10:12 PM
Don B's Avatar
As I mentioned earlier, the third wire on the XJ40 sensor is just a shield against EMI/RFI. On at least two of the aftermarket sensors I purchased the shield wire was clipped at either the sensor or connector end. The schematics show that the shield does not connect to the ECM but to ground/earth.
If it proved that the shield was important, it would be fairly simple matter to slip some solder wicking braid or braided shielding sleeve over the sensor wires and connect it to ground.
The connector swap should be easy using the connector from your old CPS. I seem to recall that the XJ40 CPS connectors changed at least once. I know they were different on our '88 and '93.
Cheers,
Don
Wayne Ormrod
May 15, 2021 05:36 AM
JensenHealey
XJ40 ( XJ81 )
Mar 5, 2020 09:58 AM
ebrisec
Jun 21, 2018 07:21 AM
dmpsqrd
Mar 13, 2016 06:33 PM
Idrivejags
Dec 1, 2008 07:26 PM
