XJ40 ( XJ81 ) 1986 - 1994
Evaporator - FIXED
Old Apr 19, 2010 | 06:34 AM
Cadillac's Avatar
Default Evaporator - FIXED
I am led to conclusion that my evaporator needs to be fixed due to A/C leaks one after the other .
So, how hard can it be to get it fixed ? It's said front console needs to be come off to gain access it , is that right ?
Old May 16, 2010 | 09:09 AM
Cadillac's Avatar
Finally, evaporator replaced by a new one and hopefully it will be ok . I no longer hear a " breathe in / out " sound which was an oddish one lol
Here are a few pics of the new evaporator which was installed
Old faulty eva on the table as you can see . I presumed something bigger lol
Attached Thumbnails Evaporator - FIXED-16052010083.jpg   Evaporator - FIXED-16052010084.jpg   Evaporator - FIXED-16052010088.jpg
Old May 16, 2010 | 11:43 AM
Hey Caddy, you are falling down on the engine cleaning. The last pics I saw of your engine, it was spotless.
Mind you I can hardly coment, my 92 looks as though it has just finished the Dakar. LOL
Old May 16, 2010 | 12:20 PM
Cadillac's Avatar
Yup, I think you're right , it will be spotless again
I like your sense of humor
Old May 16, 2010 | 12:34 PM
MyBlackCat's Avatar
Cadillac.
That looks more like an expansion valve.
The evaporator looks like a heater core and is found inside the passenger compartment.They tend to get plugged up over time just like heater cores.
Most times we would replace both since they are usually side by side and a crappy thing to change and the heater core has to come out to get at the evaporator. This might not be the case with all Jags????
Old May 17, 2010 | 01:38 PM
Cadillac's Avatar
That's true MyBlackCat , you're right and recently I was told that another XJ40's evaporator replaced due to similar problems .
My passenger compartment was removed to access the evaporator .
Old May 17, 2010 | 03:51 PM
Fraser Mitchell's Avatar
The component most prone to leaks is the condenser at the front of the car near the radiator, (it is itself a min-radiator). These go because they get everything flung at the car as it drivers along, like water, and particularly, salt-water. Prognosis is they last about 10 years, unless of course, you live in the US in a sunshine state
Old Sep 9, 2010 | 12:11 AM
babbah's Avatar
Hello - I am new to the forum and when I'm logged in as me and try to view one of the attached pictures I get this error message:
babbah, you do not have permission to access this page. This could be due to one of several reasons:
  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
What do I need to do to be able to view your pictures? Thank You
Old Sep 9, 2010 | 04:51 AM
Cadillac's Avatar
Hello,
You need to contact our admin to lift all the restrictions for you
https://www.jaguarforums.com/forum/s...t=35504&page=6
Old Sep 9, 2010 | 06:46 AM
MidwestJag's Avatar
I had the breathe-in breathe-out sound being produced whilst using the A/C. It sounded like Darth Vader! After getting the system recharged a couple of weeks ago, the sound has been eliminated. Perhaps a common sign of low refrigerant?
Old Sep 10, 2010 | 04:12 AM
Cadillac's Avatar
Nope, I don't think it's only a sign of low refrigerant but a tell tale sound that warns you about a major problem .I had heard breath in breathe out while I had almost full A/C in the system and predicted it was something more than charging A/C
aholbro1
Dec 29, 2024 06:46 PM
Russ Graber
Feb 23, 2019 11:59 AM
GordoCatCar
Jan 2, 2017 01:10 PM
Saturbo
Sep 8, 2015 07:35 PM
