XJ40 ( XJ81 ) 1986 - 1994
Fuel pressure issues?
Old May 2, 2019 | 09:41 AM
91calijag's Avatar
Default Fuel pressure issues?
So my car will lose power and sounds to be backfiring in the intake area. My fuel pressure at idle is 35 PSI, and with the regulator vacuum removed it goes up to about 44 PSI.
However, when driving and putting the engine under load, the PSI drops at times to near 20 PSI. This drop seems to correspond with the backfiring and lack of power.
I haven't been able to find data related to what the PSI should be while the engine is under load. Could the drop in pressure be related to the backfiring and lack of power?
Thanks..
Old May 2, 2019 | 11:20 AM
nunger1330's Avatar
Sounds like it is starving for fuel under load should be higher not lower. You may have a weak pump or bad check valve in the module. Does the pressure hold after you cycle the pump on and off?
https://www.jaguarclub.com/wp-conten...al-Haynes1.pdf
Here is a manual for the car. Beginning of chapter 4 will have all the values you are looking for. Best of luck.
Old May 2, 2019 | 10:28 PM
91calijag's Avatar
Thanks for responding. It was the pump. There was sand or rust particles and what looked like deteriorated fuel line pieces at the inlet,,, yes it made it pass the pump strainer!! And this pump is only 2 yrs old!!
Runs strong now...
digimurda
Feb 12, 2021 08:03 AM
RacerXK
Sep 7, 2017 10:17 AM
hdsg
Jan 6, 2014 04:04 PM
Skid Mark
Feb 5, 2013 10:22 PM
Spurlee
Mar 26, 2011 06:23 PM
