XJ40 ( XJ81 ) 1986 - 1994
Gearbox problem frustrating.
Old Apr 30, 2020 | 07:55 AM
Johnreed's Avatar
Default Gearbox problem frustrating.
Hi I'm new to the forum and would appreciate some help.i purchased a 1991 xjr 4.0.always wanted one.i seem to have a problem that the car won't start unless i move the gearstick down between park and reverse.the lights on the indicator will light up p when I'm in r or d when I'm in n.the starter will engage and keep running when I'm moving the lever through the shifts.its like it's confused.i cleaned as many earths around the body that I could find.any help would be greatly appreciated.thanks.
Old Apr 30, 2020 | 08:40 PM
jerry_hoback's Avatar
Hi John, Welcome
It sounds like your shifter just need an adjustment. This would be done on the transmission end of the cable on this car. The switch is behind a tin cover on the left front corner of the trans. There is a write up on the procedure in the Haynes manual. I had thought it had been loaded into the stickies section but now I dont see it. Maybe someone can help Me out here.
Good luck and dont forget to post an intro in the new member section.
Old May 1, 2020 | 08:50 AM
Don B's Avatar
Hi John,
Welcome to the Jaguar Forums! It's great to have you with us!
If you will search the XJ40 forum for the keywords Park Neutral Switch you will probably find a lot of information on your symptoms. Use the Advanced Search function in the drop-down menu under the Search button above, or just use Google to search this forum.
The Haynes manual Jerry refers to is available from this forum in a mostly-complete U.K. Edition. Here's the link:
Haynes Jaguar XJ40 Repair Manual
Please do visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Old May 1, 2020 | 06:23 PM
Gah! Thanks Don. I thought I looked there. But I always have trouble with Media fire anyway.
Old May 5, 2020 | 02:37 PM
Johnreed's Avatar
Thanks so much guys.im going to give your advice a try over the weekend.i realy appreciate it.
hibernianscribe
Jul 1, 2014 12:56 AM
godlej
May 24, 2013 08:52 AM
Aaronhannemann
May 14, 2013 05:03 AM
mcleist2
Jul 27, 2011 08:02 PM
Richsheik
Jun 17, 2010 03:51 PM
