XJ40 ( XJ81 ) 1986 - 1994
HVAC issues again
Old Jun 4, 2020 | 08:52 PM
Mr.Hotrod's Avatar
Default HVAC issues again
Hello everyone, I have a new issue to sort out. My Vanden Plas did not have functional hvac for the longest time, I replaced the climate control module with no practical result, then randomly it decided to work a week ago. Tonight I shut it off, and back to nothing. When I turn the knob to activate the system I hear a relay click and the sound of vacuum being applied but no lights on the panel and no blower motor. Any input would be appreciated. Its too hot to be without AC.
Old Jun 4, 2020 | 11:19 PM
Mr.Hotrod's Avatar
I'll update my own thread with a resolution, I took my old control unit, soldered a bridge wire across the two pins of the microswitch, and installed it, now I have lights, fans, and directional control. Therefore the "tested good" module I purchased is in need of a microswitch, and will be the recipient since it's got a much nicer faceplate than the original. Anybody know if I'll cause any damage running it like this for a while till I can find a switch locally?
Old Jun 5, 2020 | 09:41 PM
Don B's Avatar
Hi Mr. Hotrod,
If your hack has just replicated the "closed" position of the switch, I should think you can operate it continuously that way until you get a new switch.
Cheers,
Don
captusnr
Apr 22, 2015 09:16 AM
rfaia
Jul 11, 2014 03:45 PM
bhamilton
Jan 26, 2014 03:19 PM
Fixer88
XJ40 ( XJ81 )
Sep 24, 2012 10:32 AM
WhyDidIBuyaJag
XJ40 ( XJ81 )
Jul 20, 2012 10:08 PM
