Light on warning sound?
Hello, as i have found out its suppose to be a beeping sound when you forget to turn off your lights? Mine does not? If i leave it in Drive or anything but Park its making a sound from under the steeringwheel but nothing when i the lights are still on? I guess it's the same speaker, what can be the cause of this? Having a hard time to remember to turn off my lights so i'm afraid i will end up with a drained battery.
Is it something wrong with my lightswitch, or is there some relay or something i need to check because i looked around today but could not spot anything.
best regards!
best regards!
There are 2 different sounds there. There "car not in park" noise is a very fast beeping. It goes for about 30 seconds and stops. The "lights left on" sound is a slower sound and higher pitch- maybe 1/2 the speed of the other. I doubt that your light switch is the problem if all your lights work as they should. I have not had this problem but maybe you can check in the owners handbook to see if it can be (and someone has) turned the light alarm off manually.
Hi Simon,
Welcome to the Jaguar Forums! It's great to have you with us.
It will help others help you if you will visit your User Control Panel (User CP) and find the Edit Signature option in the left-hand menu and add the year, model, engine and mileage details of your Jaguar to your signature so that information shows up in all of your posts.
Also, please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Cheers,
Don
The speaker is a common failure point. If I recall correctly, it is a standard size, 2 inches/50 mm diameter, but its impedance is something like 60 ohms instead of the more common 8 or 16 ohms. I've used standard 8 ohm speakers as replacements, but the ones I've used were not as loud as the original 60 ohm speakers. This may be due to the new speakers being less efficient or to an impedance mismatch between the speaker and the amplifier output stage. The good news is that using an 8 ohm speaker is unlikely to fry the amp due to excessive current draw, at least based on my own experience.
If you can find a 60 ohm speaker with a magnet about the same size as the one on the original speaker you may have better results than I've had.
Cheers,
Don
Cheers,
Don
Sentinelist
Jul 5, 2013 09:54 AM
