XJ40 ( XJ81 ) 1986 - 1994
Lost all power ?
Old Mar 24, 2018 | 08:34 PM
Yonni's Avatar
Default Lost all power ?
I put the jumper leads on the wrong way and lost all power ? XJ6 Sovereign 1993, help
Old Mar 25, 2018 | 02:27 AM
rhomanski's Avatar
Ouch!
Welcome to the forums.
Please post an intro thread in the new member area. GGG will be able to direct you to the proper forum.
You may have an easy problem or a difficult one. The people with the same car as yours will be better able to help.
Enjoy the drive.
Old Mar 25, 2018 | 06:40 AM
Welcome to the forum Yonni,
I've moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
Old Mar 25, 2018 | 09:35 AM
Don B's Avatar
Hi Yonni,
Welcome to the Jaguar Forums! It's great to have you with us, but I'm sorry for your problem.
If you're lucky, you may have just blown a fuse. Start with the fuses in the right hand A-pillar fuse box, then the center fuse box, then the left A-pillar fuse box (in order of their proximity to the battery).
You can download the Electrical Guide here:
Jaguar XJ40 Electrical Guide 1993
Please keep us informed.
Cheers,
Don
Old Mar 25, 2018 | 07:27 PM
JBzXJ40's Avatar
Owner of a independent I used to work for did this to a customers vehicle.
I had found some fuses had blown, replaced them. All was ok.
I'd start by going through the fuse boxes and replacing any blown fuses, then check to see if the vehicle starts etc....
Old Mar 27, 2018 | 07:50 PM
Yonni's Avatar
Thanks for all suggestions and to you Don for the link, checked all fuses and ok, my main concern other than not turning over is no power to dash, l have power to the radio, clock, seats, also checked the inertia, will persevere, cheers
Old Mar 29, 2018 | 09:44 PM
Don B's Avatar
I seem to remember in our '93 there was one fuse that, when it blew, would cause your very symptoms: no instrument cluster and no starter engagement. I want to say it was in the left A-pillar fuse box, and it may be fuse B5 (10A), which supplies power to the instrument cluster power supply. It would be worth double-checking that fuse.
Cheers,
Don
Steve Mileman
XF (X260)
Oct 21, 2021 06:26 AM
harlock
Jan 28, 2020 12:45 PM
unclenry
Apr 6, 2018 10:55 AM
Greatdane
XJ40 ( XJ81 )
Mar 7, 2018 09:52 AM
iramphal
Feb 15, 2018 05:33 PM
