XJ40 ( XJ81 ) 1986 - 1994
Lower Shock Absorber Bush for xj40, 1992
Old Mar 24, 2022 | 01:14 AM
jagmaniak's Avatar
Default Lower Shock Absorber Bush for xj40, 1992
Hi,
I have a problem with lower bush in rear absorbers, they need replacement, but according to the data I poses there is no original replacement. Do you know if there is an alternative solution? I dont want to buy new shocks just because there is a bush issue. Pls help.
I am open for mods, etc. If you have any ideas for modifications / use of smth which just fits and does the job, it will be great too.
Old Mar 24, 2022 | 07:17 AM
katar83's Avatar
Someone will be able to confirm but if yours is using early shocks then yeah no replacement available for bottom bushes, if it's using late shocks then you can get replacement bushes, they are the same things as on later x300 cars and even early x308.
For the early shocks I suppose you could machine couple spacers for the shock eye, use later bushes, press them into the spacer and then the whole thing into the shock? Shouldn't be too difficult or pricey? I believe the bolt going through the bush is the same size on both shock types.
Old Mar 24, 2022 | 07:44 AM
jagmaniak's Avatar
yes, this is early shock - like this:
https://parts.jaguarlandroverclassic.../brand/jaguar/
this is joint ball bushing, and the one from newest model does not fit
yes i tried to find smth as a mod, but all I am finding has the hole for screw 14mm max, and in my case the hole should be 21mm
the max size of bushing should be 47mm
Old Mar 31, 2022 | 09:59 AM
Don B's Avatar
Hi jagmaniak,
Welcome to the Jaguar Forums! It's great to have you with us.
I have not worked on an early XJ40 recently, but I have done shocks on X300s and X308s recently and found that the cost of new shock absorbers was only a little more than the cost of new lower bushings, so I did not bother with the hassle of replacing the bushings. The new shocks also come with new yellow foam rubber bushings for the shaft, so to do the rears, you would only need to also buy the big yellow foam rubber spring isolator bushings ("donuts") and the small rubber "Top Hat" bushings.
Your original shocks were probably made by Boge. The closest modern equivalents are by Sachs (Boge and Sachs are now both owned by ZF). Bilstein, Monroe and KYB are other options.
Cheers,
Don
Old Apr 1, 2022 | 05:05 AM
jagmaniak's Avatar
hey, already bought KYB, but according to seller there are no foams included.
i think it is more expensive than just bushings, but problem is there are no bushings...
so no other option - was hoping about any MOD known in the xj40 lovers comunity, but no luck.
Old Apr 1, 2022 | 02:32 PM
Don B's Avatar
All of the Boge, Sachs and Bilstein shocks I have purchased have come with new yellow foam rubber cylindrical bushings, Parts 13 and 15 in the diagram below, as well as new dish washers, Part 16, and shaft nuts, Part 17. You will also need new Top Hat bushings, Part 14, and new spring isolator "donut" bushings, Part 5. The Top Hats disintegrate with time and allow the shock shafts to knock against the upper mounting plates. Your donuts may not look bad when you get them out, but they harden and compress over time and lose as much as 1/2 inch of ride height. New donuts will resolve that and help improve the ride.
Cheers,
Don
Old Apr 10, 2022 | 12:15 PM
jagmaniak's Avatar
thank you, KYB 551057 https://www.ebay.com/itm/293482184293
comes without any foams,
should I move the old one to this new one - including 14 3 12 11 10?
Old Apr 10, 2022 | 01:37 PM
Don B's Avatar
You will be much happier long-term if you buy all new bushings. The old ones will be compressed or will have disintegrated. The Top Hats (14) are almost always falling apart or entirely gone, and the rest of the bushings, which are made of yellow foam rubber (5, 13 and 15) will be hardened and compressed and sometimes crumbling.
The bellows/gaiter/boot can often be re-used, and the large washer (10) and spacer (12) can almost always be re-used.
Cheers,
Don
weltidave
Feb 18, 2022 07:23 AM
cjd777
Jul 28, 2020 04:55 AM
Fla Steve
Jan 11, 2018 10:25 AM
sbreeden
Jun 21, 2012 01:15 PM
