Yes, sorry for the confusion. I do have the engine ON in the previous picture. But I do check the code display while ignition ON, engine OFF. Only PAD appears.
PAD indicates that one of the brake pad wear sensors is either coming into contact with a brake rotor (due to pad wear), or the wire in the sensor is broken, or there is a problem with the sensor wiring harness or electrical connector. You will have to resolve that issue before you can view any diagnostic trouble codes (DTCs) via the VCM.
