XJ40 ( XJ81 ) 1986 - 1994
PDU clone? OBD reader
Old Jul 17, 2020 | 01:36 PM
Don B's Avatar
Originally Posted by lenavarrete
Yes, sorry for the confusion. I do have the engine ON in the previous picture. But I do check the code display while ignition ON, engine OFF. Only PAD appears.
PAD indicates that one of the brake pad wear sensors is either coming into contact with a brake rotor (due to pad wear), or the wire in the sensor is broken, or there is a problem with the sensor wiring harness or electrical connector. You will have to resolve that issue before you can view any diagnostic trouble codes (DTCs) via the VCM.
Cheers,
Don
Old Jul 18, 2020 | 10:31 PM
lenavarrete's Avatar
OK, so I´ll take care of the sensor and then I will attempt to run a diagnostic. Thank you for the advice!
Philkitter
Sep 19, 2016 06:37 AM
afterburner1
Aug 9, 2015 01:22 PM
alexcarter
Jul 10, 2013 04:31 PM
nairnman
Nov 28, 2010 01:18 PM
ron1979
Apr 8, 2008 12:44 PM
