XJ40 ( XJ81 ) 1986 - 1994
STARTING TROUBLES
Old Dec 5, 2008 | 12:03 PM
tetanusshot's Avatar
Default STARTING TROUBLES
I have a 92 xj6 that has a weird starting problem. When its been sitting for a while (more than one day), and I start it, its fires up fine. When i shut it off and say, go in a store, get in and start it, it almost NEVER fires on the first try. It doesn't matter if i prime the pump 3 or 4 times or not. What can it be? My idle stil is staying around 800 - 1000 in neutral. No idiot light or anything else is on. Anyone know where i can get a park switch for my wipers?
Old Dec 10, 2008 | 05:33 PM
Brutal's Avatar
Default RE: STARTING TROUBLES
ok, sorry Im 1 that viewed but didnt reply, so try this. #1 issue for youre description is fuel pressure bleeding off after you shut off the car from a bad check valve in the fuel pump module, not the pump but a 1 way valve in the big white plastic module the pump sits in. To check, you need to hook up a fuel pressure gauge, start the car then shut off, it should hold pressure in the rail. If not replace the fuel pump module and pump assembly. I dont its avail without the pump. And on the wiper park switch, either a junk(er recycle yard) or call Ken @ Motorcars800-338-5238
Old Dec 10, 2008 | 05:34 PM
whiteSTR's Avatar
This always happens to my duster when the plugs are going bad.. I would try replacing them first, and if that doesn't work I would obtain a fuel pressure gauge and make sure that its where it should be.. but without seeing the car myself its hard to say, it could be anything from a fuel pump or the engine could be flooded theres just no telling.. but as I stated, I encounter an almost identical problem with my duster and fouled plugs is the usual solution..
Old Dec 10, 2008 | 05:35 PM
whiteSTR's Avatar
DAMMIT Brutal lol you replied right as I was typing an answer hahah touché...
Old Dec 10, 2008 | 05:41 PM
Brutal's Avatar
POKEY
Old Dec 12, 2008 | 09:47 AM
Geeze, I bash the forum and have people fighting to reply! LOL thats funny. Anyways, plugs are new, but like i said, if it sits overnight, it fires right up. If a valve or regulator was bad, wouldn't it do it more the longer it sat? And one other thing, where the hell do you check the fuel pressure at? Do you have to splice into the line? THANK YOU ALL FOR REPLYING!
Old Dec 12, 2008 | 10:40 AM
Brutal's Avatar
ACTUALLY IVE MADE A FUEL LINE ADAPTER FROM AN OLD RAIL/FUEL LINE FTTINGS, BUT A MASTER FUEL PRESSUE TEST KIT SHOULD HAVE IT...I KNOW OUT REACH AS THEYRE REAL EXP. I PERSONALLY WOULD GET WITH JAGTECH SINCE HE SAID HE'S IN THE SAME TOWN AND SPEND SOME MONEY
Old Dec 12, 2008 | 11:37 AM
My bud has one with a barbed T fitting. Guess i'll cut the line, splice into it, when i'm done i'll use a straight thru barbed fitting and some fuel injection clamps.
Wolfy
May 28, 2024 08:06 AM
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
Bones
Sep 8, 2015 08:34 PM
alpecsa
Sep 7, 2015 11:55 AM
