XJ40 ( XJ81 ) 1986 - 1994
Tilting Mirror and Memory Questions
Old Jan 7, 2011 | 05:32 AM
Cadillac's Avatar
Default Tilting Mirror and Memory Questions
I need some inputs from 1993-94 XJ40 Owners / Tech Guys as my manual don't state anything about how the memory function works .
So, I do have a tilting passenger mirror but it doesn't engage automatically when you put the shifter into R ,only times it works providing those steps you have push the mirror button forward (blue marked ) and the little switch must be swung to the passenger side mirror (red marked)
If the switch is left the the middle or swing to the driver's side no way tilting function works .
Not a big deal but I would like to know it is by design or mine is quirky lol
As for the memory settings, normally in memory settings you press 1 (or whatever your setting is adjusted ) and you touch the button only once, ( get your fngers off the button ) and all your comfort settings are come on(eith your fingers off ) but in my ride , you have to keep the button pressed until your settings are selected in other words you must get your fingers on the button untill the seat stops running .
If you get your fingers off during the memory call, it stops .
I confirm that memory settings are done correctly by reading manual ,so I could hear a chime after the memory was set as well
Old Jan 7, 2011 | 08:41 AM
motorcarman's Avatar
I uploaded Tech Guide S78 (Sedan Range 93MY Update) to a website that Translator provided.
The MEMORY button must be pressed until the movement stops. It is not a 'one-touch' like the later cars.
The Tech Guide has good info on the 93/94 cars.
bob gauff
Old Jan 8, 2011 | 04:03 AM
Cadillac's Avatar
Thanks for this explanatory reply
Old Jan 8, 2011 | 05:03 AM
Hey Caddie, sorry I have not boosted everything into the FAQ as yet. Will be getting on to it.
In the meantime here is the file S78
And don't forget you have direct access to the site. (PM me if required)
Thanks again Bob for sharing, much appreciated. LOL
Cheers,
Richard
Old Jan 9, 2011 | 04:12 AM
Cadillac's Avatar
LOL, thanks Translator
St.Regis
Oct 4, 2024 12:07 PM
99xk8guy
May 28, 2024 09:36 PM
VRB
Sep 15, 2015 08:18 AM
Clamdigger
Sep 12, 2015 03:43 PM
motorhead69
Sep 9, 2015 10:04 AM
