XJ40 ( XJ81 ) 1986 - 1994
torque settings
Old Mar 19, 2015 | 04:10 PM
mickvic's Avatar
Default torque settings
Anyone know the torque settings for the sub frame bolts, rear and the four locating the sub frame v mounts?
Old Mar 19, 2015 | 05:45 PM
Don B's Avatar
I think those torque specs are in the Haynes manual, which you can download here:
https://www.mediafire.com/?hx8bttsy4kxxr#3267xri9vx4v6
If you can't find them there, let me know and I'll look them up in the Jaguar Workshop Manual tonight - I have to run to a tennis date but I'll be back in a few hours.
Cheers,
Don
Old Mar 19, 2015 | 08:58 PM
mickvic's Avatar
Yeah check there don cant locate anything . Got a workshop manual cant find anything in there either.
Old Mar 20, 2015 | 01:04 AM
Don B's Avatar
I think these are the specs you need (from the JDHT DVD Service Manual front suspension torque figures section):
Crossmember inner upper bolts 22-28 Nm
Crossmember outer lower bolts 24- 30 Nm
I know Jaguar calls the subframes "crossmembers," so these must be the specs for the upper Vee mount bolts and the rear lower pivot bolts, and they must be the specs I used because they're the only torque specs I can find for the crossmember.
Cheers,
Don
Old Mar 20, 2015 | 05:31 AM
mickvic's Avatar
well fair enough ill go with that!!!
Old Mar 21, 2015 | 02:43 AM
mickvic's Avatar
30 nm seems ridiculously light for the big bolt at the lower rear sub frame....
Old Mar 21, 2015 | 09:52 PM
Don B's Avatar
It does seem light, but all the nut really has to do is keep the bolt from falling out. All the stress is on the bushing, bolt, and the brackets through which the bolt passes. There's no stress on the nut, and you don't want to tighten it so much that you deform the brackets.
Do I recall correctly that the nut is a Nyloc type? If so, the risk of it coming off is low.
aholbro1
Dec 29, 2024 06:46 PM
mrplow58
Jan 21, 2024 05:53 AM
Neil1664
Jan 20, 2022 08:59 PM
duecedriver
Dec 25, 2015 11:47 AM
chatmanx
Sep 11, 2015 07:17 PM
