XJ40 ( XJ81 ) 1986 - 1994
TPS question
Old Sep 21, 2015 | 08:39 AM
Lumppy47's Avatar
Default TPS question
The TPS on my 1993 is dead,also any used ones i have found are also not up to spec. I have a good one out of my 1990 that check out fine,the only problem is that they have different plugs(which i can change) the wires are the same colors but what i dont know is if they go to the same parts of the cpu. Thanks for any help on this
Lumppy
Old Sep 21, 2015 | 09:37 AM
Don B's Avatar
Hi Lumppy47,
You can download the Electrical Guides for the 1990 and 1993 MYs at the links below so you can compare the wiring and make the appropriate connections:
1990 Electrical Guide:
http://www.jagrepair.com/images/Elec...Electrical.pdf
1993 Electrical Guide:
http://www.jagrepair.com/images/Auto...ec%20Guide.pdf
In the meantime, have you tried prying off the cover of your original TPS or drilling drain holes to flush it out with electrical contact cleaner spray? Here's a link to photos showing how I did it on our '93:
Welcome to Jag-lovers - Members Photo Viewing Page
Please let us know how it goes!
Cheers,
Don
Old Nov 8, 2015 | 08:19 AM
mrtalkradio's Avatar
The 89-92 jags, parts will fit. Take one off put one on.
89-94, parts will fit with modifications
ogorir
Jan 18, 2016 10:09 PM
redgear
Sep 18, 2015 10:05 AM
kamiar
Sep 17, 2015 06:30 PM
pnwrs2000
Sep 17, 2015 04:04 PM
DustysSon
Sep 13, 2015 04:17 AM
