XJ40 ( XJ81 ) 1986 - 1994
Trunk release
Old Jan 21, 2016 | 11:16 AM
danomite's Avatar
Default Trunk release
Can any one tell me if it is possible to bypass or use a jumper to release the trunk lid? There is two wires going to the trunk release switch, 1-purple/green and the other is black/brown. There is no power to either. It seam like there should be power to one of them right, all fuses are good, so it's not a burnt fuse.
Dano
Old Feb 1, 2016 | 03:28 AM
It's a long time since I had an XJ40 but I think there's a relay in the release circuit. If my memory is correct then this could be a possible cause of failure.
Old Feb 4, 2016 | 09:02 PM
jerry_hoback's Avatar
Hi Dano, I'd check the switch. The power would be there and not at the truck latch until the switch is pushed. Yes, you should be able to jumper it though. Unplug both wires and build your own temporary circuit. A Haynes manual will tell you what the codes mean. Good luck.
louvit
Feb 12, 2016 10:33 AM
danomite
US Northwest
Feb 1, 2016 02:44 AM
johnspd
Jan 21, 2016 03:59 PM
kildare
Jan 18, 2016 12:17 PM
Computer Budda
Jan 17, 2016 08:57 AM
