XJ40 ( XJ81 ) 1986 - 1994
Water Leak in Driver/ Passenger Footwells
Old Mar 23, 2017 | 10:56 AM
Jagbro's Avatar
Default Water Leak in Driver/ Passenger Footwells
Took the 91 Sovereign through an automatic car wash yesterday. When I pulled out water was pouring down on my feet and on the front passenger side as well.
I've taken it thru other auto car washes before and this never happened. However, this was the 1st time thru this particular car wash. Maybe it was the angle of their sprayers...
Anyway, I'm sure there is some drain(s) that is clogged. Where can I hunt down these drains or other advise, please?....
JagBro
Old Mar 23, 2017 | 11:22 AM
jimbov8's Avatar
Have a look around the front scuttle panel.
Old Mar 23, 2017 | 11:35 AM
Jagbro's Avatar
Thanks Jim, but I have no idea what or where the scuttle panel is located. Under bonnet, base of window?
Old Mar 23, 2017 | 11:38 AM
jimbov8's Avatar
Base of the window where the wiper arms are. Somewhere under there you should find some drains.
Old Mar 23, 2017 | 11:43 AM
Jagbro's Avatar
OK, thank you...
Old Mar 23, 2017 | 12:46 PM
Lawrence's Avatar
There's a rubber drain device called the duck bill, located in the engine compartment under the wiper motor on the firewall - sometimes it gets blocked and the water in the scuttle overflows into the blowers and then onto your feet - check it isn't clogged before you do anything else.
larry
Old Mar 23, 2017 | 02:31 PM
Jagbro's Avatar
Will DO, Lawrence...
Old Mar 24, 2017 | 06:51 AM
frenchfairplaydriver's Avatar
Old Mar 25, 2017 | 08:43 PM
Don B's Avatar
Many owners, including me, removed the duckbill and left it off. My assumption is that it was designed to discourage insects and small rodents from nesting in the comfy space under the windshield cowl, but all it seems to do is clog with seeds and leaves and cause water to pool and eventually overflow into the passenger compartment.
Old Mar 26, 2017 | 07:21 PM
95Leaper's Avatar
I think it should be routine maintenance to remove that cowl panel once or twice a year,just to clean out any debris that may have gotten down there. From years of doing restoration work,I've seen many cars with a buildup of leaves in there. Damp leaves trap moisture and rust will eventually form.
Old Apr 3, 2017 | 08:37 AM
Jagbro's Avatar
So here's the duckbill of my 91' Sovereign. Good call guys! I don't think it has EVER been cleaned in it's 25+ year history (I've had the car for 2 months 56K original miles). Now the automatic shoe washing feature has been disabled!
Old Apr 3, 2017 | 08:55 AM
Jagbro's Avatar
The Grey Cat
Old Apr 3, 2017 | 09:20 AM
Happy for you
the red cat
lazy Girl
Old Apr 3, 2017 | 09:36 AM
Jagbro's Avatar
Sweet, Like the Color...
Old May 23, 2017 | 04:48 PM
BeckBeck's Avatar
Oh must check this!! I had a very surprising foot bath after the car wash the other day myself, have been racking my brain to figure out how it happened.
Old May 26, 2017 | 06:27 AM
BeckBeck's Avatar
THANK YOU!! it was absolutely packed!
So relieved it was such a simple answer to my footwell leak!
How many of you remove and keep it off vs who will chop the opening to be larger and re attach? Is it really necessary?
Duckbill #1
inside duckbill after most of the bulk pulled out
Old Jun 2, 2017 | 05:34 PM
Jagbro's Avatar
I've chose to leave it off. No issues...
