77 XJ12L transmission mount
Old Aug 19, 2013 | 10:04 AM
Bob Kontak's Avatar
Default 77 XJ12L transmission mount
22k mile garage queen and I am cleaning out some of the minor bugs for a pal. A thunking noise on anything but smooth roads and similar to bad sway bar links but a little manlier in sound. Also, no staccato action like bad links going over rough road.
I'll skip the learning curve adventures but find the bushing in the spring loaded transmission mount has disintegrated while changing the trans fluid and filter.
This has got to be a potential source of a thunking noise. However, if not, it still needs tending to.
My questions:
Should I replace the spring along with the bushing? Is is mandatory on a cream puff given the limited cycles experienced by the spring?
Is the tongue that bolts to the transmission pan under the mount saddle for added stiffness to offset the 12 cyl torque? Does it exist on 6 cyl models? It's quite a sophisticated arrangement.
Is this picture the mount bushing?
Old Aug 19, 2013 | 11:11 AM
Bob Kontak's Avatar
I do see on Jagbits where you should replace at least the spring seats when replacing the bushing. Maybe that is the simple answer.
Also confirmed the bushing is correct in my pic above.
Old Aug 19, 2013 | 01:54 PM
Fraser Mitchell's Avatar
The bush in the pic looks OK. (its a long time since replaced mine !!)
The spring doesn't usually need replacing, it doesn't get much of a hammering, it is the bush, and probably the seating that do with all the oil blown around that location.
Old Aug 19, 2013 | 02:37 PM
Bob Kontak's Avatar
Thank you Fraser. Appreciate your input.
PS: My daughter is "working" me for a Fiat 500. :-)
Old Aug 20, 2013 | 07:54 AM
Lovely little car !
Old Aug 21, 2013 | 09:51 AM
Jtestrake's Avatar
The spring works both ways in compression and tension as the Trans moves up and down. They rarely need replacing. The bush is actually a bump stop. You should also replace the rubber cups on each end of the spring. This is usually where the noise comes from. Johns Cars sell a polyurethane replacement for the rubber bush and spring seat isolators which is not so prone to deterioration when exposed to oil and Trans fluid.
Old Aug 22, 2013 | 07:20 PM
Bob Kontak's Avatar
Thank you so much. The ground side rubber cup "looks" ok but the chassis side cup was missing. It was not re-installed a few years ago at a repair shop that clearly was baffled by the whole set up. They bent the trans pan and did not put in a new bushing.
I have only one cup (I thought I was ordering two) so I will call John's Car's in Dallas tomorrow and order both.
Below is a picture of the old bushing and a picture of all the parts save the second cup.
Attached Thumbnails 77 XJ12L transmission mount-bush.jpg   77 XJ12L transmission mount-trans-mount.jpg
mrplow58
Jan 21, 2024 05:53 AM
knightofgold
Feb 11, 2016 06:03 PM
picard
Oct 12, 2015 11:56 AM
ahunt4
Sep 14, 2015 08:17 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
