adjustment for voltmeter???
Old Sep 5, 2012 | 11:48 AM
ronin's Avatar
Default adjustment for voltmeter???
Checking to see if the voltmeter can be adjusted. if so, can someone tell me how? My voltmeter reads around 11~12 volts when driving, but I have repeatedly checked the battery, while the engine is running, and see 13+ volts. I'd like to adjust the voltmeter so that it reads properly. is this possible?
Thanks,
Eric
Old Sep 5, 2012 | 02:18 PM
Doug's Avatar
Never tried it but, yes, there is (I'm told) an adjustment screw on the back of the voltmeter itself.....at least on the mid-late Ser IIIs with Veglia gauges.
Old Sep 5, 2012 | 05:57 PM
FastKat's Avatar
Yea, mine does the same thing. My meter shows 14.1v but my gauge reads somewhere in the low 12's.
Is that back of that gauge tough to get to?
Thanks,
Eric
Old Sep 5, 2012 | 07:23 PM
Doug's Avatar
You can probably reach it if you remove the under-dash trim panel. If not, it isn't difficult to undo the bracket and pull it thru the dash. There's probably .....ha ha, probably....enough harness length to leave it connected while you make your adjustment
Old Sep 5, 2012 | 09:24 PM
ronin's Avatar
I think to access the voltmeter the tach is supposed to be removed, supposedly by turning the face counter-clockwise, I believe. Then reaching through and unsecuring the voltmeter, allowing it to come though the dash. Having said that, I have half heartedly tried turning the tach faceplate with no success. Anyone tried this approach?
Eric
Old Sep 5, 2012 | 11:31 PM
Doug's Avatar
I always forget whether it's clockwise or counter-clockwise but you have to push inward rather forcefully while turning.
FTR, whichever direction turning removes the tach, the opposite direction removes the speedo.
1983turbojaguarxj6
Jan 11, 2025 10:28 PM
Rocky15
Oct 12, 2015 03:42 AM
Johncy2000
Oct 2, 2015 01:05 AM
gunlocators
Sep 30, 2015 08:05 AM
