Alternator Startup Delay
Old Nov 24, 2008 | 03:26 PM
JagtechOhio's Avatar
Default RE: Alternator Startup Delay
There is a single terminal lead (18 gauge, it's a small wire)that plugs into the back of your alternator...it's an "exciter" wire, and if that lead is open circuit the alternator won't start charging until engine RPM's are at least 2000. Check connection at alternator.
Old Nov 24, 2008 | 05:57 PM
The capacitor is for radio supression, and has nothing to do with nothing. There is a brown/ black color coded wire with a single Lucar female spade connector: that plugs onto a male spade terminal for the alternator field winding, on the back of the alternator. If you follow it back to source, it is routed behind the A/C compressor, tywrapped to the fuel return pipe at the front of the cylinder head (along with the A/C compressor clutch feed wire and the leads to the air pump diverter valve), through the engine wiring harness to CF3 (right bulkhead multiplug), to the battery warning light on the dash.
Old Dec 6, 2008 | 04:24 PM
Doug's Avatar
After you've checked the exciter wire etc to make sure the charging circuit operates don't be too surprised if your voltmeter is still slow to react. Every Ser III I've driven has a lazy voltmeter. Sorta like a morning sickness type of thing
Old Dec 6, 2008 | 06:06 PM
The"headlights brighten" comment in the original post precludes a voltmeter inaccuracy.
Old Dec 6, 2008 | 07:48 PM
Doug's Avatar
ORIGINAL: JagtechOhio
Good point....I missed that !
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
10 XF Premium
Oct 2, 2015 09:22 PM
waynepaulj
Oct 2, 2015 04:05 PM
CaptainHam
Oct 1, 2015 02:01 AM
