A/C Hose Connection Threads
Old Jan 15, 2018 | 07:48 AM
yachtmanbuttson's Avatar
Default A/C Hose Connection Threads
I'm getting ready to reassemble my A/C hoses. Do I use anything on the threads of the hose nuts to seal them better?
Thanks, Bill
Old Jan 15, 2018 | 08:08 AM
Doug's Avatar
No. The seal is accomplished by o-rings inside the fittings. Just use new o-rings; no need for anything on the threads.
Old Jan 15, 2018 | 09:36 AM
icsamerica's Avatar
Thanks, Bill
Which car? The 75 would have flare fittings, No orings. The series 3 got orings.
The flare fittings do leak, expecially with R134a. I use a semi-hardning thread sealer just to keep them tite and flare seals to slow leaks.
https://www.flaretite.com/flaretite-seal
I use this, not to seal but prevent loosening and protect threads.
https://www.permatex.com/products/th...hread-sealant/
Old Jan 18, 2018 | 08:05 AM
WOW! Great reply... thank you. It seems there are several styles of the faretite seal and sizes? Any ideas which ones for my 1975?
Old Jan 18, 2018 | 11:19 AM
icsamerica's Avatar
Purple copper.
45° SAE Refrigeration and Gas
Part Number: 37FT-XX-CU-SPP and 45FT-XX-CU-SPP (xx = seal size)
Old Jan 19, 2018 | 10:27 PM
Robert Wilkinson's Avatar
Nylog makes a sealant specifically for A/C fittings of all types. There are "red" and "blue" varieties depending on refrigerant type.
Old Jan 20, 2018 | 11:30 AM
The XX being seal size. Do I need to know and provide that?
Old Feb 6, 2018 | 11:31 AM
Anyone ever made up their own A/C hoses?
Old Feb 6, 2018 | 01:06 PM
icsamerica's Avatar
Yes. I buy fitting from coldhose.com and use this crimper for a/c and power steering hoses. I always try to start with an OE hose and then put the right end on to adapter to the applications. For hard lines, I cut and weld as necessary.
Amazon Amazon
pamco
Apr 12, 2013 03:56 AM
randyb
Apr 29, 2012 02:03 PM
moonpetal38
Apr 16, 2012 08:45 PM
hunter34
Oct 20, 2010 11:56 AM
