Central door locks
Old Aug 27, 2016 | 04:38 PM
jordanmc's Avatar
Default Central door locks
Hey everyone,
My series II central door locks are not working correctly. When I press the button to lock or unlock the locks all make lots of clicking noises and try to operate. Then no power for 30 seconds or so. Where should I start? Are there just 2 relays under the back seat?
Old Aug 27, 2016 | 07:33 PM
The reason you have no power for that 30 seconds is you've tripped the thermal overload. It's there to keep from letting the smoke out of the actuators.
To fix it you must remove the door liners and lubricate all the lock linkages. Start with a rear door first as there's less 'stuff' to deal with.
Old Aug 28, 2016 | 09:18 PM
thedugger1's Avatar
I second that. I had dodgy locks, spent the time to lube everything methodically and they've worked fantastically since. It's a good first step that's for sure.
iconic
Apr 11, 2016 12:51 PM
Andi Baker
Apr 9, 2016 05:51 AM
JimC64
Jul 20, 2015 09:32 PM
Apr 7, 2007 06:20 AM
aquill1
Dec 23, 2006 12:56 PM
