Central locking problem
Old Aug 23, 2021 | 02:14 AM
Hktk's Avatar
Default Central locking problem
Central locking/unlocking from the driver's door has stopped working. It happened after I removed the car battery for charging purposes. Has anyone experienced something like this? Can someone guide me please?
I can open the doors manually, that is not a problem but the central locking function no more works. I drive Series 3 1985.
Old Aug 23, 2021 | 05:34 AM
redtriangle's Avatar
Fuses?
Old Aug 23, 2021 | 07:42 AM
Doug's Avatar
Fuses are always the first place to look.
1985 was a transition year for two entirely different central locking systems.
The Lucas (early) system used lock solenoids. The Kiekert (later) system used lock motors.
The Lucas system used a circuit breaker and a fuse. The fuse is #17 in the RH fuse panel. It also covers the door lights and power mirrors....so if those are working the fuse is OK. The circuit breaker can be tested with a test light ....or by momentarily bypassing it. It is on the RH component panel. Looks like this:
The Kiekert system has only an inline fuse on/near the RH component panel. The fuse holder will have brown and brown/blue wires
Old Sep 18, 2021 | 02:35 AM
Hktk's Avatar
Checked the fuses as advised. All fuses seem to work.
Any other advice?
Thanks.
Old Sep 18, 2021 | 09:06 AM
Doug's Avatar
Any other advice?
Thanks.
The locks are commanded by the control unit in the driver's door----which itself is operated by turning the lock with your key or by the inside paddle.
Perhaps the linkage to the control unit has fallen off.
Perhaps the control unit has failed.
Perhaps there's a wiring/connector problem preventing the control unit from getting power and/or delivering power
I'd remove the trim panel for a look-see and some checks with a test light or volt meter. We can help here...but you'll need to let us know if you have Lucas or Kiekert central locking as the wiring is totally different
Old Sep 18, 2021 | 08:19 PM
Hktk's Avatar
I found these next to the fuse box. They seem to work.
Will this image help in identifying whether the system is Lucas or Kiekert central locking? Thanks.
Old Sep 20, 2021 | 11:57 PM
Andy T.'s Avatar
Those two are the thermal breakers for the electric windows. If you have the solenoid door lock system, there should be another thermal breaker that looks like that but with wires coloured N and NU. It would be located on the same panel slightly inboard.
Old Sep 26, 2021 | 01:59 AM
Hktk's Avatar
I haven't fixed the door lock issue but today the speedometer stopped working. What I have gathered from online research is that it could be due to a faulty transducer. Where can I locate the transducer? Or I need to start somewhere else.
I am in Australia and drive a RHD.
Old Sep 26, 2021 | 02:32 AM
Andy T.'s Avatar
The transducer does commonly fail. You will find it on the RH side of the transmission case near the output flange with a 2-wire connector attached. You could check this connector first as a bad contact there could cause a lack of reading. As regards a replacement, they are availble from the usual UK suppliers, e.g. Martin Robey, SNG Barratt, David Manners part number DAC4570 for the auto box. Not sure about suppliers in Australia.
Old Oct 9, 2021 | 01:34 AM
Hktk's Avatar
Hi, can someone please direct me to the correct fuse/relay in the image below​​​​ that could have caused the electric door issue (central locking stopped working a few weeks ago)?
Thanks.
Old Oct 9, 2021 | 08:13 AM
Doug's Avatar
If you have the Lucas system there are two lock relays located in the left and right footwells, behind the 'kick panels'.
If you have the Kiekert system there are no relays
AussieDart
Apr 28, 2021 12:50 PM
Hazel Cartwright
Apr 14, 2017 02:31 PM
Rickxj6
May 27, 2016 03:26 AM
MJG
Dec 8, 2012 04:07 PM
tom_the_coat
May 22, 2008 05:33 AM
