Centre Steering Wheel Bolt
Old Mar 29, 2021 | 01:54 AM
adenshillito's Avatar
Default Centre Steering Wheel Bolt
The Centre Steering Wheel Bolt on a Series 2 ; what to remove with. >? my 7/8 socket fits over it but does seem to grip. the bolt is a hexagonal bolt. would i require like a 21mm or 22mm socket.? or is this some techanogical magic beyond me//
Old Mar 29, 2021 | 02:36 AM
LT1 jaguar's Avatar
Active Streak: 60 Days
I can't tell you whether there is any magic involved, but if 7/8" (equivalent of 22.225mm) slips, I would go for the 22mm. If that doesn't fit well, try the 21mm. Good luck.
Dave
Old Mar 29, 2021 | 02:39 AM
I was surprised that the 7/8 (which sat in place nicely) just slipped around the outside of the bolt.
Old Mar 29, 2021 | 10:34 AM
That "bolt" is only nylon and not tight at all. Should be only finger tight.
And then you'll find a brass tube about 6 inches long with another nylon fitting over it that activates the horn.
Getting this back into proper position can be fiddly.
Old Mar 30, 2021 | 11:19 PM
tried 21mm and 22mm (which appeared almost same as 7/8) and finally a 24mm (which worked but a tiny bit loose). a 23mm might have been the creature, but it's done now. thanks
Old Mar 30, 2021 | 11:23 PM
no, that one came out easily as you say, but now you have mentioned the nightmare of getting it back in right I have the image of the bomb disposal guy who is told 'cut the red wire' and as soon as he does the advisors says "wait, no green wire"
it's all oily etc that dip stick thing etc.
was the bolt underneath as it was a 23/24mm to remove. now on the lower level and wondering how the next bit comes off. -thanks
Old Mar 31, 2021 | 04:03 AM
NOW I GET IT.
That "bolt" is what we call a NUT. 15/16AF is ringing dim bells in the grey matter.
Old Mar 31, 2021 | 05:04 AM
I managed to spend two weeks engaged in a back and forward email exchange with a service desk woman in the USA because she was using one terminology and I was using by NZ terminology and we were 'fixing' different software things entirely.
I got the bolt off but now there's strange stuff i don't get like a grandfather clock dial.....
Old Mar 31, 2021 | 08:59 AM
This is why I post pictures whenever I can. Few people will misunderstand a good photo of the problem.
But that's just me........
Later today I'll dig around in my Nix albums and see if I have a photo of the steering wheel assembly under the wheel itself. I had my fingers in it, but that was 6 years ago. I do remember it wasn't as scary as it looked, mostly because I only had to change the position of the wheel and didn't have to work on anything under it.
Jag1968
May 27, 2021 10:39 AM
scz4
Apr 30, 2020 02:13 AM
sanchez
May 8, 2019 07:45 PM
jamdmyers
Mar 15, 2015 02:00 PM
jahummer
Feb 24, 2015 10:39 PM
