Connector
Old Feb 10, 2016 | 04:37 AM
adenshillito's Avatar
Default Connector
connector off the right hand (drivers) side of the series 3 radiator, what's it for and where go too?
also I can see the temperature sender nub on the engine but it has no spade or connector? should i purchase and after market replacement or can I attach a 'spade link' or such to it and where/what is the cable that should attach to it.
Old Feb 10, 2016 | 08:38 AM
Doug's Avatar
Offhand I'd say that's the connector to the radiator-mounted thermo switch that controls the electric fan
I'm not sure if I understand the question.
But, the wire for the temp sender is usually green
Old Feb 10, 2016 | 01:10 PM
I can see the temperature sender thing on the engine but it doesn't have a connector on it to attach a wire too .. does that make sense?
Old Apr 17, 2016 | 02:49 AM
Who do the TWO PINS on the radiator's temperature plug as pictured above work?
xxxscimitarxxx
Feb 4, 2017 06:28 AM
frontrunning
Aug 9, 2016 01:54 AM
Hoppy
Feb 12, 2016 01:14 AM
TexMurphy
Feb 11, 2016 07:13 PM
rdssdi
Feb 10, 2016 03:08 AM
