engine dies when I come to a stop...
Old Jan 15, 2017 | 12:13 PM
new mexico's Avatar
Thanks a million for that picture, I will take a look when I take the cover off.
I can also compare it to the other one I have as a spare.
Walter
Old Jan 15, 2017 | 12:19 PM
new mexico's Avatar
Smile Afm 78 xj6
Thanks for the picture, I will check it out.
Just joined this forum, have used the jaglovers for years, and getting
used to this one. It sure is different.
Walter
Old Jan 16, 2017 | 03:13 PM
new mexico's Avatar
Default AFM problem
Originally Posted by ronin
I thought I'd offer a follow up on my issues listed above for anyone in the future who may read...
Most everything is square now and here are some results:
For the random engine cut out issue, it turns out the AFM was causing my problems. Under the black plastic cover on top of the AFM is a rheostat looking arm that was loosing connection sometimes which would then cut fuel resulting in my engine dieing. The arm tension was retightened and I have not had anymore issues.
For the random heat/cool A/C, I swapped the amplifier out for a new one and all is well. I did have to recharge the system, and I am cool now, even in near 100 degree F weather.
I have taken care of a number of other items in the name of preventative maintenance - tightened timing chains, replaced hoses, new fan and fan clutch, fixed exhaust leak, installed tappet hold down kit, etc. and have been driving daily to and from work (~30 miles one way). So far so good.
What is everyone averaging in mpg? Just curious. I'm pretty consistant with 15-16mpg average (60-70% highway driving).
Thanks,
Eric
Eric Could you please explain how you fixed the arm in the afm and how
you can tell if you fixed the stalling problem???
Old Jan 16, 2017 | 03:23 PM
new mexico's Avatar
Default XJ engine stalling
Could somebody please be specific on the AFM fix, and to tell if the
stalling of the engine is fixed?
Thanks, Walter
Old Jan 17, 2017 | 08:47 AM
JagCad's Avatar
Walter:
Can't help much with your Jaguar issue. I was forced in to a radical fix of mine.
But, although I am a Texan, I live in California, I've always had an affinity for New Mexico. Adventures there as a kid and later in the beginning of my business career.
Carl
Old Jan 23, 2017 | 12:12 PM
Dutch-Cat's Avatar
Originally Posted by ken@britishparts.com
Check for vacuum leaks for the stalling problem. They will drive you crazy.
That is weak for the alternator, but use an external gauge or have the Autozone boys use their battery and charging system tester. Most in dash gauges are not that accurate.
That was exactly the problem on my '86 V12:
When returning to idle, the engine would turn at approx. 450rpm and then slowly die. Checked out the vacuum system and found that the kick-down hose on the tranny had come loose. Fixed that and she idles beautifully now.
Old Jan 25, 2017 | 01:44 PM
JagCad's Avatar
You are quite welcome. some has been fun and some quite the other way.
The DOHC and BW 66 are gone. In their place is an LT1 SBC and 4l60E transmission.
Not voluntary, but, quite satisfying. I liked it as it was and enjoy it as it is.
I term it English elegance with an Italian flair and reliable American power.
I particularly enjoy the OD. 70 MPH or so at about 1750 RPM. Yet plenty of urge on adding more pedal...
Carl
dsnyder586
Dec 29, 2024 07:39 PM
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
