Entering radio code 87 XJ6
Old Jan 24, 2011 | 04:42 PM
Dollajaaag's Avatar
Default Entering radio code 87 XJ6
Hey all,
I had to disconnect my battery to do some electrical work, and now i need to enter a code to unlock the radio. I have the code, the only issue is entering it. I'm not sure if you need to enter the physical code or push each button a number of times (ie. 3-4-5-2-1 would mean push #1 3 times, #4 4 times etc..). Also, what position should the ignition be in when entering the code?
Old Jan 24, 2011 | 07:47 PM
Doug's Avatar
Key "on"
The stations buttons should be numbered (as I recall...been years since I had one) so you'd push button 1 once for "1", push button 2 once for "2", etc etc
Old Apr 15, 2011 | 10:12 AM
introvertimages's Avatar
Where you able to get the issue resolved? I am having the same problem.
Thanks!
Old Apr 21, 2011 | 09:58 PM
bbarcher's Avatar
On my 87 it is easy to enter the code like Doug said. I found my code written on the radio itself luckily.
philwarner
Oct 4, 2024 01:37 PM
1100me
Jul 24, 2023 06:10 PM
cissdm
May 3, 2016 06:02 AM
TexasCat
Sep 8, 2015 04:36 AM
